Tiller decision
/ Tiller decision #1
Anonymous Poster
Epic Contributor
I was just at the local tractor dealer. He has two used 50" Yanmar tillers. One is an RS1200 (green) and the other is an RSA1302 (red). Does anybody know the differences between the two and which one would you recommend? He's asking $700 for either one. I thought I saw one on here for $350 , but now I'm wondering if that was a too good to be true deal. I'll be using it on a YM2000B. Thanks for any and all info........ Ernie in NE Ohio
/ Tiller decision #2
Ernie
I just purchased a used 1303 (green) with gage wheels
for $400. This was Lowes of Ind. and the last one they had
for the time. I am looking for any/all instructions for
use and upkeep. If you come across any please let me know.
/ Tiller decision #3
I have a RS1200 green with the original mount that fits a 1401 for sale for $250 + shipping from So Calif. Unless you weld some ball sockets on the rods that connect it to the lift arms, you have to unbolt your lift arm 3pt pins and use the tillers rod mounts. Not a big deal. I also sell other used Yanmar tiller models for $250. Most need a wire brush and some paint, but all work good. Or save on shipping and pick them up. If you buy 2 or more and pick em up, then $200 each. I can post some pics if you like.
Jim
/ Tiller decision
Jimbo
Thank you for the offer. That sounds like a great price, but since California is too far for me to drive and I won't buy anything sight unseen I'll have to pass on that one. I can see though that $700 is pretty steep for a used tiller. Maybe I'll be able to find something a little closer. Thanks again Ernie
/ Tiller decision #6
had a RSA1302 and it did a great job tilling. Needed chaincase oil changed but after that it was great! Worked well even in our heavy clay soil with sod growing on it. Second pass always makes it much better!
Nick
/ Tiller decision
Thanks Rich. Now I need to go to the map and see exactly where
Amsterdam is. That seems a bit better than $700........... Ernie
/ Tiller decision #10
Jwjimbo, what size is that RS1200 tiller? I've got a Yanmar tiller that I use with my 1401D, but it is a sort of "bastardized" 3 point setup. It's nearly impossible to lift it far enough off the ground to keep it from dragging over rough terrain. I'm not sure what model it is. It's 48" from tine to tine. It does not have the adjustment handwheel that I've seen in pictures of other tillers. I would like to set it up like the original 2 point setup it was designed for but I'm not sure what I need or how it goes together. If you would post pics of your setup it would help me alot in figuring out what I need. Thanks.
/ Tiller decision #11
E-mail me for a picture of my 1401D setup. My file is too big and I don't know how to reduce it.
Eugene
buppy69@bellsouth.net
/ Tiller decision #12
Hosejockey,
I will try to get some pics when I get home, hopefully before dark
Jim
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
CASE IH 290 AFS MAGNUM TRACTOR (A64280)
CASE IH 290 AFS...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
AUGER SUMPS, FLIGHTING & MISC (A63291)
AUGER SUMPS...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
