Tighten Your Loader Bolts
   / Tighten Your Loader Bolts #2
Pulls pins out.. Don't lose those parts HAHA. Miss wood block. Looks like the name of the game is keeping those bolts torqued. I just bought some torque sticks for my lugs so I can just zap them with the impact and be at least close. I have quite a bit of hand tools I work on my own diesel trucks (duramax lb7 and a 7.3 powerstroke) But I have nothing that will fit my loader bolts they are a whole different beast. So its time to buy more tools, yay. I like your Mahindra videos and I like your farm. Keep up the good work.
   / Tighten Your Loader Bolts #3
glad to see you use the thread locking compound. Loctite blue 242?
Thank You. A lot of times (often) I’m learning while I’m doing😂
   / Tighten Your Loader Bolts #5
Your best advice? Whenever dropping loader, do it on solid surface-concrete or asphalt. Amazing how quickly the loader gets "crosswise". And by the looks of your Mahindra, with only one center grounding point it makes it even worse IMO
   / Tighten Your Loader Bolts #6
thanks to ledgemere farm i have a 2021 1626 2/3s of the bolts were loosen thanks again tex.
   / Tighten Your Loader Bolts #7
I used LokTite Blue on all my wheel lug nuts and on the FEL lug nuts. I've also used it at various locations on most of my ground engagement implements.
   / Tighten Your Loader Bolts #10
I wish I had watched this last year. I failed to keep the bolts tight and ending up searing a number of them and being loose ended up cracking the frame. I had to remove the frame and have it welded and now I have to remove the seared ends of the bolts to reattach it. Since I had to totally disconnect the FEL hydraulics from the frame, I must have done something wrong since now the 3 Point won't elevate. Fun times when you don't do the regular maintenance.
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2015 CATERPILLAR 299D XHP SKID STEER (A51242)
2015 CATERPILLAR...
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
