tighten belts?
/ tighten belts? #1
sergeant69
south texas
troy bilt horse and pony
seems like the belts are slipping/squealing a little too easily. put an 8 HP Honda on a 71 horse!. belts are new. can the distance between the upper and lower pulleys be increased? thanks
/ tighten belts? #2
Try following the attached link. I did not use the " tool" they refer to, i just adjusted back and forth until the belts stopes squealing and yet it shifted into position easily. The link may nt be exactly like yours, but it should be close. I don't know which model that is.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=horsebeltadjustment.pdf
Also some instructions on the reverse disc yo asked about previously.
http://service.mtdproducts.com/references/reverse_disk_service.pdf
/ tighten belts?
cool. exactly what I needed. thanks!
/ tighten belts? #4
Like I mentioned, don't get too worried about the tool they have, just adjust back and forth until you get it not to squeal but stay in position. Good luck.
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2013 ELECTRO-STEAM INDUSTRIAL PRESSURE WASHER (A65054)
2013 ELECTRO-STEAM...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
PORTA POTTY (A68842)
