tighten belts?
/ tighten belts? #1
sergeant69
south texas
troy bilt horse and pony
seems like the belts are slipping/squealing a little too easily. put an 8 HP Honda on a 71 horse!. belts are new. can the distance between the upper and lower pulleys be increased? thanks
/ tighten belts? #2
Try following the attached link. I did not use the " tool" they refer to, i just adjusted back and forth until the belts stopes squealing and yet it shifted into position easily. The link may nt be exactly like yours, but it should be close. I don't know which model that is.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=horsebeltadjustment.pdf
Also some instructions on the reverse disc yo asked about previously.
http://service.mtdproducts.com/references/reverse_disk_service.pdf
/ tighten belts?
cool. exactly what I needed. thanks!
/ tighten belts? #4
Like I mentioned, don't get too worried about the tool they have, just adjust back and forth until you get it not to squeal but stay in position. Good luck.
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
John Deere XUV825E (A61307)
John Deere XUV825E...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
80003CFL (A61568)
80003CFL (A61568)
