tighten belts?
   / tighten belts? #1
sergeant69
south texas
troy bilt horse and pony
seems like the belts are slipping/squealing a little too easily. put an 8 HP Honda on a 71 horse!. belts are new. can the distance between the upper and lower pulleys be increased? thanks
   / tighten belts? #2
Try following the attached link. I did not use the " tool" they refer to, i just adjusted back and forth until the belts stopes squealing and yet it shifted into position easily. The link may nt be exactly like yours, but it should be close. I don't know which model that is.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=horsebeltadjustment.pdf
Also some instructions on the reverse disc yo asked about previously.
http://service.mtdproducts.com/references/reverse_disk_service.pdf
   / tighten belts?
cool. exactly what I needed. thanks!
   / tighten belts? #4
Like I mentioned, don't get too worried about the tool they have, just adjust back and forth until you get it not to squeal but stay in position. Good luck.
2011 Ford Escape XLT SUV (A48082)
2011 Ford Escape...
2022 Club Car...
2014 Big Tex 12ft. S/A Utility Trailer (A48082)
2014 Big Tex 12ft...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
UNUSED White Metal Roof Panels (A50860)
UNUSED White Metal...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
