Tig Torch Adapter
/ Tig Torch Adapter #1
roadhunter
Elite Member
Wyoming
JCB 212SU
I was watching some tig welding videos this weekend and decided I was going to give it a try the next time I had a chance. I have a ESAB 161 that has a lift start tig setting and have always wanted to see how well it works. I have a tig torch I came across a few years ago but never hooked it up until today. When I did today I found that the torch I have had the wrong end. Torch has a Dinse 35 (1/2") and the machine requires a Dinse 25 (3/8") connector.
I did some searching and found the adapter I need but I have not been able to locate one here in the United States. Here is the adapter I am needing. I do not need it to allow gas through the fitting.
Dinse Type Adaptor Converts 10 25MM² Sockets to 35 50MM² Sockets Free Post | eBay
Or this
Dinse Type Adaptor 1068 Converts 10 25MM² Sockets to 35 50MM² Sockets Qty x 1 | eBay
Anybody have an idea where I might find one of these in the states?
/ Tig Torch Adapter #2
Roadhunter, you may have a hard time finding that configuration.
I would just purchase a large female Dinse and a small male Dinse. Attach each to an end of a short length of cable.
Terry
/ Tig Torch Adapter
Terry,
I hadn't thought of that. I appreciate the help.
/ Tig Torch Adapter #4
You can easily swap out the dinse plug from your 50mm to the smaller 25mm. Easy to change. There are only 2 sizes. E-bay has good deals on dinse look a likes and they work fine. Any welding supply has them as well for more $$.
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
120in. Fork Extensions (A61572)
120in. Fork...
Caterpillar Service Magazines (A63117)
Caterpillar...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
