Tig machine cooling
/ Tig machine cooling #1
Big Orville
Case 580 CK
I bought a dial arc Miller back in 1980. I did not start using this machine until 2017 because the cooling fan was messed up. I use an air cooled torch that gets too hot to use after a bit. I just found a 200 amp water cooled torch that I bought in 1981. There is one water line going to the torch, no return line. the machine has a water supply going to one side of a valve, after the valve one line going to the torch. how can this work without a return line. I was planning on buying a cooler with anti freeze solution in it. I would think it would need a supply and return to cool the water. Is this machine so old that things have changed?
/ Tig machine cooling #2
Mine has a supply and a return line from the torch. I don't use AF in mine, I use distilled water. My shop is heated in the winter.
/ Tig machine cooling #4
hot water discharged to yard, with a hose keeping the supply going. Cheaper than maintaining a cooling system.
David from jax
water in hose and water out is through the power cable is the way I see it.
I am going to look at that power cable a little closer, I did not see that possibility, but I was not looking for that option. Looks like I will need to get a new torch to run a cooler. Years ago at work the return line went into a floor drain. I did not look at how it was plumbed. If I would have I would have forgotten by now. Thanks for the pictures.
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
215603 (A63276)
215603 (A63276)
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2022 EZ-GO ELITE...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
