Tig machine cooling
/ Tig machine cooling #1
Big Orville
Case 580 CK
I bought a dial arc Miller back in 1980. I did not start using this machine until 2017 because the cooling fan was messed up. I use an air cooled torch that gets too hot to use after a bit. I just found a 200 amp water cooled torch that I bought in 1981. There is one water line going to the torch, no return line. the machine has a water supply going to one side of a valve, after the valve one line going to the torch. how can this work without a return line. I was planning on buying a cooler with anti freeze solution in it. I would think it would need a supply and return to cool the water. Is this machine so old that things have changed?
/ Tig machine cooling #2
Mine has a supply and a return line from the torch. I don't use AF in mine, I use distilled water. My shop is heated in the winter.
/ Tig machine cooling #4
hot water discharged to yard, with a hose keeping the supply going. Cheaper than maintaining a cooling system.
David from jax
water in hose and water out is through the power cable is the way I see it.
I am going to look at that power cable a little closer, I did not see that possibility, but I was not looking for that option. Looks like I will need to get a new torch to run a cooler. Years ago at work the return line went into a floor drain. I did not look at how it was plumbed. If I would have I would have forgotten by now. Thanks for the pictures.
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
