Tig break test.
/ Tig break test. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
I did the Tig test this morning. Set the machine at 250-amps for these 1/4-inch thick flatbar plates. I wasn't in the pedal fully at all times. Used 1/8-inch ER70S-2 filler rod, 100 % argon, about 18-cfph, 1/8-inch Ceriated tungsten.
I couldn't get a full 1/4-inch weld in one pass. I tried stuffing enough filler into the puddle to do it, but I could tell it wasn't digging into the heel / root, so I settled for little less than 3/16-inch. I let the plates cool to the touch, and broke it. 6-blows is all it took.
So I ran another coupon, but this time I made a 3-pass fillet weld, and got a full 1/4-inch weld.
It took 13-blows to break the plate, and when it broke it snapped!
/ Tig break test. #2
you mean cfpm (minute) and 'thoriated'? (alloyed with thorium) :)
red stripe 2% thoria
/ Tig break test. #3
No he means cfph because tig welding uses much less then one cfm, and also that is just a differnt kind of tungsten.
/ Tig break test.
Nope, cubic feet per hour.
Nope, Ceriated, (orange tip) tungsten. I welded this with an inverter machine.
/ Tig break test. #5
I don't know why you couldn't do that.
I use 3/32" tungsten with 1/16" rods and can get 1/4" welds all day long.:)
Greg
/ Tig break test. #6
Greg
what amperage are you using, what kind of tungsten, and what gas. (argon or helium)
/ Tig break test.
Greg
That's because you're better than me! :thumbsup:
/ Tig break test. #8
You slacker weekend welder warrior :rolleyes:
Sheesh. You even know how to make something hard look easy. That TIG weld looks perfectly awesome.
The typically accepted engineering terms are cfm and cfh cubic feet per minute and cubic feet per hour. The "p" is not typically noted, like in PSI ... Pounds per square inch. And yes, most inert welding gasses are in the cfh range.
/ Tig break test. #9
Pardon the silly question. I thought a proper weld actually melted and fused the two pieces. The filler just being there to reinforce. Isn't the fact that it only took a few hits with a hammer a sign that it was a cold weld? I'm confused.
/ Tig break test. #10
The filler and the base metal all become one piece, the filler is there to add enough material so that it will have enough thickness there, and to fill gaps in the fit up.
/ Tig break test.
Why is that Mark, is the ER70S-6 stronger? Seems like I was looking for -6 but had to settle for -2.
/ Tig break test. #13
70 S-6 seems to wet in better, and has a high level of deoxidizers. And in my experience is fairly ductile.
/ Tig break test. #14
I doubt that. If I came off sounding arrogant I apologize.:ashamed:
I don't even have any formal training. I pretty much taught myself what I know and that isn't saying much.
What you're saying is a 1/4" weld is probably a correct weld,compared to what I would think it is.
deereman75
I use a Lincoln Idealarc 300 AC/DC,not sure of the year,but I think it's from the late 80's early 90's.
When I weld 1/4 inch plate,I have it set on high,36/215,but I have the fine control on about 7.5,so I'm not using the full amps. I use 3/32" 2% Thoriated, "red" and 1/16" ER70S-2 rod (in fact the 70S is all we've ever bought).Gas is 100% Argon.
Greg
/ Tig break test. #15
deereman75
Greg
Ahh the classic lincoln idealarc, oh how I wish I had one of those.
/ Tig break test. #16
I saw you can buy tungsten in 7 inch lengths, I am wondering how you cut them, isnt tungsten incredibly hard?
/ Tig break test.
What I do is put them 45 degrees to the outside edge of my bench grinder wheel, grind a groove in the tungsten, then break it over the edge of the table. Then grind the desired point on each end.
/ Tig break test. #19
Ahh ok that makes sence. Also how much differnt is tig welding from gas welding, like if I am good at gas welding, how hard would it be to get good at tig welding.
/ Tig break test.
They say the fastest way to learn Tig is to start with O/A. I haven't done any O/A welding in just under 100-years:laughing:, so I can't hardly remember what it's all about. I do remember it being very hot.
The similarities of the two processes are, forming the puddle, then dipping the filler. Personally I think Tig welding is easier to make a nice looking bead.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
XTREME XR1147 TELESCOPIC FORKLIFT (A65056)
XTREME XR1147...
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
Location Tampa, FL. Year: 2017 Make: Dodge Model: Durango Vehicle Type: Multipurpose Vehicle (MPV) (A64557)
Location Tampa...
