Tier 4 issues
/ Tier 4 issues #41
Mahindra and others like Massey Ferguson, kubota etc are now using EGR and DOC catalyst. The DIesel Oxidation Catalyst cleans up the exhaust soot similar to catalytic converter in your gas powered cars and trucks. They will fail and clog. The EGR DOC route is not as clean as the DPF route. Some companies have put fear into people saying that your barn will burn down if you put a tractor with a DPF in it. The DPF is under the hood with heat shielding around it. It has no more heat than a regular exhaust pipe. I have had a diesel car with a DPF since 2009, no problem parking it in my garage, even if I interrupt a regen. I have had zero DPF issues.
A car or truck is not used like a tractor.
/ Tier 4 issues #42
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2008 Ford E-250 Cargo Van (A59230)
2008 Ford E-250...
