Throttle tension adjustment?
/ Throttle tension adjustment? #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
On my new 4300, I've noticed that I move the throttle up to where I want it, let go, and it moves back down a bit to a slower position all by itself. It takes a lot of fiddling to get the RPMs to stay where I want them.
Opening the hood and pulling the side panel makes it obvious that, if there is an adjustment for this, it must be up under the instrument panel cowling somewhere? I don't have my tech manual yet for this machine, so I'm wondering if anyone can suggest the best way to get at the adjustment?
The Deere dealer said they had never had to adjust one before, and could only suggest pulling that cowling and looking around a bit.
Anyone been there, done that?
Thanks,
Bob
Bob Trevithick
/ Throttle tension adjustment? #2
Yes, been there done that. If you remove the 4 or so screws holding the instrument panel down and lift it up, you can barely get access (without major tearing apart) to a nylon inserted nut that clamps a friction plate against the throttle lever. If I remember correctly, you'll need two open end wrenches, one to grab the nut and the other to grab the head of the bolt. Kind of awkward getting in there without taking too much apart, but it can be done.
Tom
Thanks, Tom! I guess I will be tinkering tonight. Not that I mind tinkering, mind you... /w3tcompact/icons/smile.gif
Appreciate the reply!!
Bob Trevithick
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
