Throttle/Pedal?
/ Throttle/Pedal? #1
Laconia BL-475
Ingersoll Rand BL-475
I have a TBL Ingersol Rand BL475. The RPM's are dictated on the peddle, except when using the backhoe, there is a separate lever. If the lever is used and you step on the peddle, the peddle overrides the lever. Having said that, I have a snowblower. I need to run the RPM's high when using that. My problem is that in order to do that, I have to have the peddle to the floor which also moves the machine forward. I need to control the forward movement independently from RPM's. I believe most heavy equipment has both a throttle lever along with a separate pedal. I am wondering if there is a way to separate to two with a kit. Any help you can give me would be much appreciated.
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
TEREX 2300 TEREX 60TON CRANE (INOPERABLE) (A67714)
TEREX 2300 TEREX...
2022 John Deere 6175M (A64911)
2022 John Deere...
2013 Chevrolet Impala Sedan (A66738)
2013 Chevrolet...
