Throttle lever drifts back to idle
   / Throttle lever drifts back to idle #1
BSLMS
Upstate NY
Yanmar 424
I have a 424 with 125 hours on it. The throttle lever will no longer hold a set RPM, it keeps drifting back to idle. It seems as if something needs to be snugged up a bit. What am I looking for, where is it located and what is the procedure for restoring the friction needed to hold a throttle setting?
Anti help,would be appreciated, thanks.
   / Throttle lever drifts back to idle #2
Lots of looks but no help. I'll take a stab, but I know nothing of your tractor. If it's a lever type throttle, there would likely be a friction disk set up where the lever pivots. I would try and tighten that pivot. It's probably a bolt as a pivot and you would just tighten the nut.
Kim
Thank you KW, it has to be something simple, just needed a little direction.
   / Throttle lever drifts back to idle #4
I have this same problem, however my RPM drifts down to about 2500RPM. I was thinking there must be a spring somewhere but the friction disk makes more sense. Will look under the console today.
BSLMS where in upstate are you located?
Hi Helio, I'm in Guilderland.
   / Throttle lever drifts back to idle #6
SHREDDER (A52472)
SHREDDER (A52472)
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
ARMSTRONG  10 FT DISC (A52472)
ARMSTRONG 10 FT...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
