Throttle lever drifts back to idle
   / Throttle lever drifts back to idle #1
BSLMS
Upstate NY
Yanmar 424
I have a 424 with 125 hours on it. The throttle lever will no longer hold a set RPM, it keeps drifting back to idle. It seems as if something needs to be snugged up a bit. What am I looking for, where is it located and what is the procedure for restoring the friction needed to hold a throttle setting?
Anti help,would be appreciated, thanks.
   / Throttle lever drifts back to idle #2
Lots of looks but no help. I'll take a stab, but I know nothing of your tractor. If it's a lever type throttle, there would likely be a friction disk set up where the lever pivots. I would try and tighten that pivot. It's probably a bolt as a pivot and you would just tighten the nut.
Kim
Thank you KW, it has to be something simple, just needed a little direction.
   / Throttle lever drifts back to idle #4
I have this same problem, however my RPM drifts down to about 2500RPM. I was thinking there must be a spring somewhere but the friction disk makes more sense. Will look under the console today.
BSLMS where in upstate are you located?
Hi Helio, I'm in Guilderland.
   / Throttle lever drifts back to idle #6
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
John Deere S780 Combine (A53342)
John Deere S780...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
