Throttle lever drifts back to idle
   / Throttle lever drifts back to idle #1
BSLMS
Upstate NY
Yanmar 424
I have a 424 with 125 hours on it. The throttle lever will no longer hold a set RPM, it keeps drifting back to idle. It seems as if something needs to be snugged up a bit. What am I looking for, where is it located and what is the procedure for restoring the friction needed to hold a throttle setting?
Anti help,would be appreciated, thanks.
   / Throttle lever drifts back to idle #2
Lots of looks but no help. I'll take a stab, but I know nothing of your tractor. If it's a lever type throttle, there would likely be a friction disk set up where the lever pivots. I would try and tighten that pivot. It's probably a bolt as a pivot and you would just tighten the nut.
Kim
Thank you KW, it has to be something simple, just needed a little direction.
   / Throttle lever drifts back to idle #4
I have this same problem, however my RPM drifts down to about 2500RPM. I was thinking there must be a spring somewhere but the friction disk makes more sense. Will look under the console today.
BSLMS where in upstate are you located?
Hi Helio, I'm in Guilderland.
   / Throttle lever drifts back to idle #6
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
