THROTTLE CABLE FROZE
/ THROTTLE CABLE FROZE #1
smilindave
Dayton, Pa
Power Trac 425
I've been having problems with the throttle cable sticking on my 425. Last week I went to start it and this time the throttle won't budge. Tried putting oil and WD 40, but still no movement. I even tried hitting the throttle with a hammer! Still nothing. Any ideas on where to get a new one? It's about 105 inches long. I tried all the local places and no one had one available. Any thoughts?
/ THROTTLE CABLE FROZE #2
Is the throttle cable a typical wire-wrapped, plastic coated stiff wire cable? If so, here's a trick I learned to lube the throttle and shift cables (2 each) on my 1987 twin 350 inboard. Pick up ~12"-15" of plastic tubing with an ID that'll fit over the throttle cable, a tire valve stem and a couple of small screw hose clamps. Unhook both ends of the throttle cable and clamp one end of the tubing onto the upper end of the cable. Fill the tubing with Marvel Mystery Oil (or equivalent), stick in the valve stem and clamp it in place (tightly). Pump a bit of air into the tube through the valve stem. As the air forces the oil to flow into the throttle cable, add a bit more air. Go slowly, and lay the other open end of the cable on a rag. When the oil starts to ooze out of the cable, you've lubed it. It worked fine for me but YMMV.
Charlie
/ THROTTLE CABLE FROZE #3
I use motorcycle chain lube on my throttle cable and associated linkage, I tried several different lubes and unfortunately wd40 attracted lots of dust and aggravated the sticking situation
/ THROTTLE CABLE FROZE #4
I called PT the other day. Ordered a new throttle cable for my PT-422. $26 It comes with the lever.
/ THROTTLE CABLE FROZE #7
Throttle cable and lever was $26 UPS shipping was $14. Total was $40 and change. Pleasantly surprised.
/ THROTTLE CABLE FROZE #8
Frank, did they ship you just the cable? They keep telling me that there is a minimum $75 parts order...
Of course, coming up with $75 worth of stuff to order is usually not a problem, but it does send me to local hardware stores looking for alternatives, if I only need something minor...
/ THROTTLE CABLE FROZE #9
Hi Kent,
that was it. I didn't have to order anything else.
Frank
/ THROTTLE CABLE FROZE #10
Wonder if it is because I bought my PT used? But, that's what they tell me, as recently as a few weeks ago when I ordered another QA plate for the Ingersoll/Case tiller I mounted for it...
/ THROTTLE CABLE FROZE #11
It used to be $50 minimum order.
But filters, a couple blades for the brush hog, a few of those bushings for inside the brush hog blades, and you can get there pretty quick.
/ THROTTLE CABLE FROZE #13
The T-8 plate was $175, up from $150 when I purchased the last one a couple years ago...
/ THROTTLE CABLE FROZE #15
Brand new PT-425. Brought to ND, throttle handle "froze", meaning I cannot lower the throttle. I will call Tazewell tomorrow, but maybe there are some ideas here? Maybe it did literally froze? It's ND, baby.
/ THROTTLE CABLE FROZE #16
When you get your new one installed it'd probably be a good idea to add to your winterizing routine a spritz utilizing this:
Motion Pro 08-0182 Cable Luber....$10 on Amazon
/ THROTTLE CABLE FROZE #17
That's a neat invention. My issue is that the tractor is brand new. 0.1 hours on it.
/ THROTTLE CABLE FROZE #18
Mine froze on a 1430 within the first 20 hours and they sent a new cable out under warranty. The replacement cable has worked fine for the last 500 hours and through Wisconsin winters. Terry thought the cable got kinked during assembly.
/ THROTTLE CABLE FROZE #19
My guesses would be either water in the cable that froze or it's pinched somewhere from factory. Mine seized up after about 16-17 years. They weren't too hard to change, but they are tie-wrapped somewhere in the tunnels, so take your time and don't force anything. Also, mine had decades of dirt and grime in the tunnels, and yours will be nice and clean, so that's good. I changed both the choke and throttle cable as a pair. There's a specific order in doing it to make it a lot easier on yourself. As I recall, I had to take them out at the dash board, pay attention to the spacers behind the dash on one of the cables if yours has them, or the lever will hit the steering wheel when you re-assemble in incorrect order (ask me how I know this). I had to cut the old cables off of the levers, tape the end of the new cable to the cut off end of the old cables, and use the old cables to pull them through. They'd get stuck every time I hit a tie-wrap. Took some skinny hand to get into the tunnels to cut them. But I think it ended up being less than an hour job.
/ THROTTLE CABLE FROZE #20
What is the term for the mechanism that throttle and choke cables attach to? Anyway, I tried to move the mechanism itself. The choke lever moves easily, but throttle lever doesn't move at all.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Agline ADM110 Hay Mower (A64047)
Agline ADM110 Hay...
2004 John Deere 330 CLC (A61166)
2004 John Deere...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
CRAFTSMAN 20 GALLON ELECT. AIR COMRPRESSOR (A62131)
CRAFTSMAN 20...
