Three Point Hitch valve issue
/ Three Point Hitch valve issue #1
BlackDogTx
Waller, Texas
LS G3038H, Kawasaki Mule 3010 Trans Diesel
Hi,
Has anybody else had any issues with the valve that controls the speed of the raising and lowering of their 3 point hitch? Mine locks up all the time.. You then have to fiddle with it for several minutes, sometimes shut down the tractor and restart it.. Fiddle with it some more before it finally unsticks and begins to allow the 3ph to drop? Irritating..
/ Three Point Hitch valve issue #2
Havent had that problem. Must be some trash in the valve. Might be able to take out the stem completely and see if you can flush any thing out of it.
/ Three Point Hitch valve issue #3
Had the same issue I think.
On mine (G3033) , approx 3 inches behind the valve knob is a lock/ jam nut that either has come loose or was never properly
tightened.
The knob turns freely both ways and if you can completely unscrew it that is likely your problem.
Remove the 4 bolts holding the seat for easy access .
Interesting. Thanks for the advice.. I need to replace the seat safety switch this weekend anyways as it broke off and I had it jumpered while waiting for the replacement switch from the dealer.. I will check that out this weekend..
..Eric
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2022 Case TV450B (A64126)
2022 Case TV450B...
BushHog 2615L 15ft Batwing Rotary Cutter (A65640)
BushHog 2615L 15ft...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
