Three point auger conversion
/ Three point auger conversion #1
chance60
washington pa
mccormick
I would like to know if anybody knows what size hydraulic motor i would need to convert my three point auger to hydraulic drive.I would like to drive it with skidloader with 15gpm an 3000 psi
/ Three point auger conversion #3
Or you can do what I did which was just buy a wheel motor and mount it onto my bits. Pictures are on the net and I can point you the way if interested.
/ Three point auger conversion #4
15 GPM into the motor that woodlandfarms posted will turn the hyd motor at 361 rpm, and that is lower than the PTO speed of 540.
If your auger gear ratio is about 1.5 : 1 you can expect a speed of about 248 rpm.
It should work quite well, and you can reverse the auger if you get stuck.
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
