Three point auger conversion
/ Three point auger conversion #1
chance60
washington pa
mccormick
I would like to know if anybody knows what size hydraulic motor i would need to convert my three point auger to hydraulic drive.I would like to drive it with skidloader with 15gpm an 3000 psi
/ Three point auger conversion #3
Or you can do what I did which was just buy a wheel motor and mount it onto my bits. Pictures are on the net and I can point you the way if interested.
/ Three point auger conversion #4
15 GPM into the motor that woodlandfarms posted will turn the hyd motor at 361 rpm, and that is lower than the PTO speed of 540.
If your auger gear ratio is about 1.5 : 1 you can expect a speed of about 248 rpm.
It should work quite well, and you can reverse the auger if you get stuck.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Attachments, implements, & more 2/26/26 6pm online only (A64047)
Attachments...
Wolverine Skid Steer Stump Grinder (A64047)
Wolverine Skid...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
