Tractor Sizing Thread Size
/ Thread Size #1
phatgemi
This may seem an odd question but I will not be near the tractor for a while and wish to get a head start on parts gathering.
My threads are a bit messed up on the front axle spindle. I do not have metrics dies but wish to purchase the correct die for thread cleanup. What size do I need for the spindle nut on a YM2000 2WD? I.E. M18 x 1.5 or what????
Thanks in advance for any info.
/ Thread Size #2
If you have the parts book check diagram 12, part 12 (I'm saying this just so you know there is a ready source to check all those bolt sizes on the tractor). It shows the bolt size as 14x25. So 14mm is your diameter, and I know it is referred to as "standard" metric thread...I think that is 1.5. Someone else will undoubtedly know. The couple tap/die sets we have in the shop have at least two variants, maybe three for most diameters. You can buy a set from Harbor Freight for under $50 (or at least you could a few years ago)....one of ours came from there and has held up very well.
/ Thread Size #3
The spindle nut is 20m, not sure on the pitch.
Danny
/ Thread Size #4
20M x 1.5
Danny
/ Thread Size #5
In a situation like that I would recommend a thread chasing file. The are quick, and only repair what is needed without harming existing threads. I have use them alot in different situations. With one 4 sided double ended file you have about every possibility.
Mike
213088 (A64276)
213088 (A64276)
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2022 EZ-GO ELITE...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2006 Ford F-250 4x4 Crew Cab Pickup Truck with Liftgate (A64556)
2006 Ford F-250...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
