thoughts on TYM machines
/ thoughts on TYM machines #1
20 20
Elite Member
adirondacks
Hey folks, just wondering how you feel about the TYM's. Trying to find out about reliabilty, especially sizes from the T433 down to the T233. I really like the T233 but never had HST before and am wondering how strong the little machine is? I am also wondering how well the cabs hold up and are made? thanks for any info, facts or just plain ole opinions
/ thoughts on TYM machines #2
We have TYM 330 HST that we bought new. The tractor has about 500 hours of non abusive mostly hard FEL work. There was a leaking sight on the tranny right after it was new. Got new sight for free from the dealer. It took about 5 minutes to replace. Right now the tractor has small electrical issue. The "check" light stays on even after the engine is running. When the light is on before the tractor is started means that not all interlocks are met. It is bypassed when the engine is running. Looks like some bad connection somewhere.
The tractor is used year around maintaining our driveway, bush hogging, lot of FEL work, snow removal around the house etc.
It had pretty much zero mechanical problems. Only complain I would have is peeling paint on the FEL cylinders and some pain blisters on the operator platform.
Thanks for the post, they seem like a nice tractor overall. I'm wanting something with a cab and have narrowed my search down to TYM, LS, JINMA. The LS I'm told will not come with a cab unless I go 50hp or more :(. I have found jinma and TYM both can come with cabs. I have to say the TYM just seems more attractive. I have owned a jinma in the past and can not complain, very dependable{also own the nortrac dozer}
/ thoughts on TYM machines #4
I love the title of the thread. It reminds me of "Back to the Future".
I recently purchased a used '09 293 HST, with an FEL and Erskine snowblower. Has 400 hours on it. I had a small electrical problem with the flashers and turn signals, but I can attribute the problem directly to something that the previous owner did. (Pinched wire harness because he rerouted a hydrolic line too close)
It is pretty cold blooded starting, but is fine once warmed up. A block heater is definitely coming in the future. (I'm in far northern Michigan)
Thanks Waterbug for the post, I've read where others have said they also felt TYM is cold blooded. I went one year without a block heater on a diesel up here....never again. IMO, all diesels are cold blooded especailly when that temp drops in the winter.
/ thoughts on TYM machines #6
I am in my second year with the gear TYM 433 cab, it is the forth tractor I have owned over the last thirty years and so far I am very happy with it. I did a lot of looking before I bought and in the end I was convinced that for the money it was the best buy for me.
This year I located a used 7 ft "Cat" brand quick attach plow blade for snow removal, along with the 6 1/2 ft blower on the back it is a weapon. The Cat blade is very different than most, it uses one horizontal cylinder for angling the blade making for a very compact design, Just got to use it for the first time and it works great.
Al
/ thoughts on TYM machines #7
I've owned a T233 for the past year. Only put 50 hours on, mostly cutting trails with a bush hog, and some front end loader work. Had a problem with the universal joint, but was able to repair myself with the parts provided by the dealer. Very happy overall!
Thanks for the responces and pictures, that plow sure looks like a nice setup.
/ thoughts on TYM machines #9
I've had a 233 with the backhoe for about 4 years. It came with a five year warranty, but I've had very few problems with it, and the dealer has been very good and sorting out any minor issues. It's a really solid little machine, although be careful with rocks and branches hitting the hydraulic lines and controls under the floor. The clearance is not that great. You've really got to watch what the backhoe frame is doing because it's really close to the ground.
The biggest problem I have is that I'm a bit tall for it (6 feet) and my old knees cramp up after I've been on it for a while. I keep meaning to add risers to the seats, but I never got around to it! Maybe they did something about that on the newer models?
Thanks Tiny Tym, I've asked around and from what I gather the T233 will be a bit on the small side for what I need, I do like the 300 series tractors.
/ thoughts on TYM machines #11
I have a 353HST with 60 hours on it. I use it mostly for snow blowing and log skidding. You can't beat the weight for pushing and pulling. This is my first tractor but I am pleased with it. :thumbsup:
/ thoughts on TYM machines #12
Do you need tire chains during snow removal with the 353
thanks again for the post, I have decided against TYM. It's not that I don't like them just to hard to get any solid info on them. I owned a jinma and could find more out about it{more support}. I do like the TYM's and wish them luck, seem like nice tractors form what little I could find out.
/ thoughts on TYM machines #14
I use them since I am on a hillside and have to deal with ice. I use 4 link v-bars. I am sure if you only had to deal with flat areas regular 4 links would give you all the traction you would want.
Using the blower on the flat shouldn't need chains but if you were using a front plow or even a rear blade you might get pushed around without them in deep or heavy snow.
2020 International LT625 48" Sleeper (A62613)
2020 International...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
2004 International 8600 Tender Truck (A63118)
2004 International...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
