Thoughts on Ford 861
/ Thoughts on Ford 861
temp gauge and buld is an assy. can't replace them individually. at least not the mechanical ones. keep an eye on that thrust play. it should have 0 ideally. if it hit 1/16 i'd pull the pto..
is she on 12v?
Yep 12v now, but wondering if the fuel gauge is still 6v... At any rate when you hook the sender to the gauge, it buries the needle all the way left.
/ Thoughts on Ford 861 #22
Lots of good info Soundguy, you've done enough of those old Fords, you could probably do one in your sleep.:laughing: I remembered the point gap and plug gap, but didn't know the firing order is different than the old IH and Case tractors. Neighbor had an SC Case and he could take four fingers on the plugs when it was running and kill it dead, hurt just to watch him do that.
OK, parts on order. Some from Wegners and some from Tractor Parts Express. The picture of Wegners aftermarket manifold looked dead on. We will see. Soundguy mentioned that all "new" manifolds are the same thing now, fitting the 801 series better than the 800 series. I will post back and let you know how it goes.
Chris
/ Thoughts on Ford 861 #24
yep.. the universal fit will likely be easier on t he larger 01's etc.
/ Thoughts on Ford 861 #25
Just picked up a used one for my 861 today. Snapped clean off at the elbow flange mount :( :(
/ Thoughts on Ford 861 #26
ouch!
That's where mine came apart also! Except it was "helped" by a hammer...:eek:
/ Thoughts on Ford 861 #28
oh my.
was it one of those trying to tap on something.. glanced off and then the hammer hit the most expensive thing near it? usualy what happens to me.
I dmage a 400$ hood panel trying to pry out a 50 cent clip.. :)
is she on 12v?
Was going to order parts for the PTO bearing replacement and saw there were two shaft seal sleeves on tractor parts express. My parts book is at the lake 300 miles away.
TPE shows 310087 and 9N73538 sleeves. Cheap enough to get both, but can anyone look in their parts book to see which shaft sleeve I need? Thanks! Chris
/ Thoughts on Ford 861 #30
i doubt it's the one with a 9n number.. :) the other number is a later sequence..
/ Thoughts on Ford 861 #31
ps.. you should have the large and long stub shaft correct?
/ Thoughts on Ford 861 #32
Here are some screenshots from my NH iPhone app showing the part numbers that I believe you are looking for:
/ Thoughts on Ford 861 #33
that sleeve i believe has been superceeded by pn: 83964336
Do you mean one long shaft instead of two with a coupler? I am not sure, but the tractor is a '58, so I think it is the one long one.
Perfect! Thanks Chris! That is just what I needed!
Chris B.
Also interesting that the CNH website does not show the diagram on my iPad, but does on the computer. Lesson learned. May have to get that app.
/ Thoughts on Ford 861 #37
I have found their app to be really handy to have on my phone. It would be real nice on an iPad. I have used their website for a good while. This app makes it even better.
I put the app on the iPad...very slick!
/ Thoughts on Ford 861 #39
no such thing as 2 with a coupler.
hit the parts site. look at that superceded sleeve number..e tc.
