Thoughts On Baumalight BrushFire?
/ Thoughts On Baumalight BrushFire? #1
CoveCreek
Tracy City, TN
Mahindra 8560 (currently shopping)
Any thoughts about this attachment for clearing about 40 acres of 2-4 inch hardwoods (thickly concentrated)?
Baumalight BrushFire - 500 Series - YouTube
They claim it can handle brush up to 6 inches in diameter.
Prices I'm seeing are between $18,000 and $20,000
/ Thoughts On Baumalight BrushFire? #2
What carrier will you be using? Also if its a one job deal or personal use id vote buying a good used head over a new one. A used Fecon can be had for low teens. Havent heard much on baumalights but the little info I have gathered suggest sticking to a Fecon,Fae, or Cimaf.
This would actually be their PTO version for an Ag tractor.
/ Thoughts On Baumalight BrushFire? #4
I find their marketing very nice (very good graphic designer, they have), and although I don't consider them as direct competitors to the industrial-class mulchers, I too would like to hear comments about the these products. How do they compare with Loftness' (productivity, durability)? How long to replace a full set of carbide tips?
/ Thoughts On Baumalight BrushFire? #5
We just bought one works great but my boss THOUGHT it would be BIG enough to clean 500ac. after a half a day found out other wise.
For sale in middle Georgia now
Ok. Here's a few questions for you Hawg Daddy.
- How much did you manage to clear in half a day?
- What size was the stuff you were clearing?
- Do you have the PTO version or skidsteer?
/ Thoughts On Baumalight BrushFire? #7
Pto verison, in the range of 2/3" scrub and couldn,t say for sure I,m not at the land.
i see. i don't need anything exact. just a rough guess. i have 40 acres to clear. i don't mind doing this 1 acre at a time for 40 days. i just don't want to do it at 1/10 of an acre per day over 400 days.
/ Thoughts On Baumalight BrushFire? #9
i am new here and i am by no means a mulching head specialist.... but am a stump grinder specialist. the teeth used on this head in question are a version of a modified stump grinder tooth. they will work well for the first 30 hrs or so, but slightly dull stump type teeth will reduce the performance substantially imo. on larger hp machines more dull teeth have some forgiveness because the hp grunts throught it. on smaller hp machines sharp teeth are a must have to be productive at all. this head seems to have many many teeth (an assumption based on the tooth style) and at im guessing 10 to 12 bucks a pop it would be very expensive to replace slightly dull teeth on a regular basis. i would find out how many teeth are on it, their cost, and whether driving unit is at higher end of the hp class capable of driving the head before going further. if it is not then you should look elsewhere imo and stay away from the stump tooth type heads
/ Thoughts On Baumalight BrushFire? #10
A ruff guess would be 1-2 acres a day he told me it eats though it like butter just too slow foe the amount of land we have to clear. Thanks HD
mulcher is in middle Ga.
/ Thoughts On Baumalight BrushFire? #11
What was the price of the unit?
/ Thoughts On Baumalight BrushFire? #13
They are all on ebay 60" skidsteer head is $22k, 48" skidsteer is right at $15k, excavator heads are from $16k-$20k 30" and 48" and pto 60" 3pt version is $17.5k.
Looking at getting some in that line for my 5065E.
Thanks
/ Thoughts On Baumalight BrushFire? #14
How many PTO hp is your tractor you will be using ? We have a Fecon BH 120 on a 140 pto hp tractor and in small 2-4 " real thick material it will work circles around our other units.
/ Thoughts On Baumalight BrushFire? #16
I think you would really struggle with only 65 hp
/ Thoughts On Baumalight BrushFire? #17
Any updates on this?
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63118)
2019 Cadillac XTS...
2009 KENWORTH T6 SERIES (INOPERABLE) (A63569)
2009 KENWORTH T6...
Adams 5 T Fertilizer Spreader (A63118)
Adams 5 T...
2010 Deere 318D (A60462)
2010 Deere 318D...
