those hyd connectors
/ those hyd connectors #1
dieselade
west cent indiana
5225 & 3720
I have a 32o5 and a 4310. the loader was on the 4310 and went to put the loader on the 32o5 and the female hyd receivers are a different size. what a bummer that was/is...what is jd thinking?????my question is...what is the best way to handle this, get a new set of female recievers for the 3205 to match the loader male tips, or get new male loader tips to match the 3205?
/ those hyd connectors #2
You should change the smaller couplers to the larger size.
/ those hyd connectors #3
You may even be able to purchase adapters that plug between the 2 different sizes! In the farming world there is alot of different adapters for all types of different application. Of course anytime you reduce line diameter you'll reduce flow rate!
/ those hyd connectors #4
I'd go with Kenny's suggestion, especially if this is a permanent swap or you expect to do this swap frequently.
Make sure you have a drain pan and a couple plastic caps (to plug the hydraulic line when you remove the QD) handy.
2001 FORD F-150 LARIAT TRUCK (A64276)
2001 FORD F-150...
2025 IR Electric Tricycle (A61574)
2025 IR Electric...
CATERPILLAR 12M3 MOTOR GRADER (A64276)
CATERPILLAR 12M3...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
