This will keep Toyota honest
/ This will keep Toyota honest #2
Why not just show a picture of it?
/ This will keep Toyota honest #3
Here is a link to some photos of the production model H4WD.com
The thing is, Honda will keep it affordable for the average human, something Toyota forgot about long ago.
I bought my first Toyota in 1982 and have had 6 other Toys since then. I still have a 91 Corolla (170K miles) and a 91 truck (140k miles) but have since switched my "brand loyalty" to Honda...I bought a 2002 CR-V that came loaded and was still $5-10K less than the base model Highlander and/or RAV4.
I'm very excited about the Ridgeline...so much so that it may very well be my next vehicle...
sorry for the rant...
/ This will keep Toyota honest #5
sort of reminds me of the cadillac truck or suv. Very nice looking truck, and I prefer the Dodge Ram Series.
Second thought, but will it pull my trailer and Kubota?
/ This will keep Toyota honest #6
ENGINE
Type: 60-degree Aluminum V-6
Displacement (liters/ cc): 3.5/ 3471
Horsepower @ rpm (SAE net): 255 @ 5750
Torque (lb.-ft. @ rpm): 252 @ 4500
Valvetrain: SOHC 24-Valve 3-Rocker VTEC (R)
Fuel System: Multi-Point Programmed Fuel Injection (PGM-FI)
Throttle Control: Drive-By-Wire
Intake Manifold: Dual Stage (Aluminum)
Air Induction: Fresh Air Intake
Emissions: (Federal/ California/ Application) Tier 2 Bin 5 / ULEV-2/ 50 State
DRIVETRAIN
Automatic Transmission (Standard): 5-speed
Heavy-Duty Automatic Transmission Cooler
Four-Wheel Drive: VTM-4
Locking Rear Differential
Maximum Rear Torque Transfer 70-percent
BODY/SUSPENSION/CHASSIS
Body Type: Integrated Closed-Box Frame with Unitbody Construction
Body Construction: Boxed Ladder Frame with Unitbody
Independent Front Suspension Type: MacPherson Strut
Independent Rear Suspension Type: Multi-Link with Trailing Arm
Steering: Variable Assist Power Rack-and-Pinion
Heavy-Duty Power Steering Cooler
Front and Rear Disc Brakes
4-Wheel Anti-Lock Braking System (ABS)
Electronic Brake Distribution System (EBD)
Brake Assist
Vehicle Stability Assist (VSA (R)) withTraction Control 4-Channel
Wheels: 17 x 7.5 J
Tires: All-Season P245/65 R17 105S
Tire Pressure Monitoring System (TPMS) with Location and Pressure Indicators
EXTERIOR DIMENSIONS
Wheelbase (in.): 122.0
Length (in.): 206.8
Height (in.): 70.3
Overall Width (in.) (no mirrors): 77.8
Wheel Track (in.) (front/rear): 67.1/ 66.9
Approach/ Breakover/ Departure Angles: 24.5 / 15.9 / 22
Ground Clearance (in.): 8.2
PICKUP BED DIMENSIONS
Length (in.): 60.0
Depth (in.): 20.7
Width (in.) (wheel well to wheel well): 49.5
Length Tailgate Down (in.): 79.0
In-Bed Trunk(TM) Volume (cu. ft.): 8.5
Heavy Duty Tiedown Cleats: 6
INTERIOR DIMENSIONS
Headroom (in.) (front/ 2nd row): 40.7/ 39.1
Legroom (in.) (front/ 2nd row): 40.8/ 36.4
Shoulder Room (in.) (front/ 2nd row): 63.2/ 62.6
Hiproom (in.) (front/ 2nd row): 57.6/ 57.2
EPA Passenger Volume: 112.0
Seating Capacity: 5
WEIGHTS AND LOAD RATINGS
GVWR (lbs.): 6050
Curb Weight (lbs.): 4552
Towing Capacity (lbs.): 5000
Vehicle Payload Capacity (lbs.): 1549
Trailer Pre-Wiring: 4-pin/ 7-pin
EPA MILEAGE ESTIMATES* / FUEL CAPACITY
5-Speed Automatic (City/ Highway): 16/ 21
Fuel (gal.): 22.0
/ This will keep Toyota honest #7
It's based on the Honda Pilot setup - I did notice that they upped the GVW 100# - probably so "businesses" can get the tax write off. I'd say it will do 95% of what I use my Ford Supercrew for better, but lacks a little in the payload & towing capacity departments. Wifey has a pilot - nice car.
/ This will keep Toyota honest #8
Wow ... maybe I should sell my dodge and start hauling things around with a honda.
Oh... but wait thats
252 ft-lbs at 4500 rpm and 5000 lb tow rating......
well the dodge is 600 ft-lbs at 1600 rpm and almost 15,000 lbs of tow rating..... /forums/images/graemlins/blush.gif
All kidding aside, when will toyota, nissian and honda get serious about a real truck?
Fred
/ This will keep Toyota honest #9
I'm sick of yet another soccer mom SUV or pickup. Soccer moms have made it to where the common guy has to go up to a 3/4 ton truck or larger to get a true truck anymore. I want a 1/2 ton regular cab truck built like a tank, but they don't exist anymore.
Squishy rides and features and slightly modified engines originally designed for cars, and on the worst even frames re-used from a car line have made most of them useless as true truck or SUV anymore and durability has gone downhill. You used to be able to buy a truck and realistically expect to get 300,000 to 400,000 miles out of it if you treated it good because they were overbuilt, rode rough, and simply designed.
/ This will keep Toyota honest #10
Oh great!!! Just what we need another plastic play truck for the soccer mom.
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
New/Unused ATS Lifting Motor (A65583)
New/Unused ATS...
