This page cannot be displayed--???
/ This page cannot be displayed--??? #1
TresCrows
Elite Member
Kansas
Kubota BX2200, Kubota B2410
I know it is not directly tractor related but since we use computers to talk about tracotrs I have yet another question.
Any guesses as to why when pulling up the Internet Explorer or Firefox or even while already on the internet such as here at TBN I move to a different forum or to a different website or just try to open the browser and I get " This page cannot be displayed. This only happens on the lap top which is wireless. The desktop continues to function normally. I have tried repowering the router (unplugging), turning the wirless button on the laptop on and off etc. The signal indicator and status indicates there is a signal--yet--"this page cannot be displayed". I have found that sometimes I just keep at it and it starts working again or if I reboot it starts working again. This only started the last few days but then only recently have I been wireless all the time with the laptop. I suspect a router problem but it could also be software such as the ZoneAlarm? or mayne some hardware issue?---what y'all think? Coincidently all AOL was removed--best I know and ZoneAlarm became the firewall. It works, it don't work, then it works--what is going on? /forums/images/graemlins/confused.gif
J
/ This page cannot be displayed--??? #2
When it happens to me it seems to be because of the site I'm trying to link to, or the link (address) has been blocked or changed. When I finally get back to the site there is usually a discussion of an earlier problem with thier server.
/ This page cannot be displayed--??? #3
I'm thinking it's a wireless connectivity issue. Since the pages display properly on your hard wired PC, that kind of lets out the actual router causing the problem. You might try changing the channel your wireless is operating on, probably currently using channel 6, what most default to. Just a guess but may be worth a shot.
Good luck.
/ This page cannot be displayed--??? #4
I'd blame it on an intermittently poor or blocked wireless signal. The error you're getting means that your browser timed out while waiting for the server to respond. More than likely, that means that packets between your wireless card and the router were either dropping or interfered with. That, in and of itself, is also not unusual since walls and/or wall composition can sometimes create problems. Just hit 'Reload' and try again, or move to another spot in your house and see if the signal isn't better.
- Jay
/ This page cannot be displayed--??? #5
I don't know, my wife has a couple of sites she goes to regularly, but one she cannot get to from her laptop loads just fine on the hardwired PC. She also gets the same message........
/ This page cannot be displayed--??? #6
Zonealram for firewall?
I use that too, next time it happens try shutting down ZA and trying the web again. My comuter does the exact same thing, restarting is the only solution I have found, though shutting down ZA does work it means that you then have no firewall.
Let me know if you find a solution, so far restarting the comp is all that will work for me
/ This page cannot be displayed--??? #7
You might want to try hitting the "REFRESH" button on your browser first. I'm not sure with wireless if the laptop is in constant communication with the router..in which case it may time out. If you refresh your current page and then go to select another forum, that may help. If not, I hope someone out there has the answer for you.
Jon
/ This page cannot be displayed--??? #8
When it's happened to me, I just shut off the wireless card on the laptop. And then cycle it back on and search for the wireless connection again. That usually takes care of it.
/ This page cannot be displayed--??? #9
I don't see what OS you are using but with the Dell D500 WIN XP that I am using when that happens to me, there is an icon in the system tray (where the clock is) that looks like a computer with ")))" beside it. I right click on that and choose "REPAIR".
This has consistantly resolved the problem. Before I started using the "Repair" feature I would disable the Wirless NIC Card, Remove, and Re-Install. That's not possible now that I can use the internal Wireless Connection. Now, the old way would be a reboot, which my wife has to do on the OLD IBM running Win98 /forums/images/graemlins/grin.gif.
Kurt
Thanks for all the helpful ideas.
The operating system is Windows XP. When this happens I have hit the "repair connection" icon and also have tried cycling the wireless power buttn. I have also disconnected the router power cord and repowered it. I am beginning to think the router is very weak, I rarely show more than two bars (out of five) and usually just one and I am probably not more than 20 feet from the the thing. I think it is intermittantly loosing solid connection if only for a micro second and this confuses the computer or gets something out of whack between the router and the computer. Sometimes it starts working again but usually I have to reboot. The router is a standard Linksys wireless G. If it is a problem with the wirless modem n the computer--built in--would using a wireless G card plugged into the computer trouble shoot that? If it worked and did not have the problem then it would be a hardware issue with myinternal wireless card? Thanks. J
/ This page cannot be displayed--??? #11
</font><font color="blue" class="small">( Sometimes it starts working again but usually I have to reboot. The router is a standard Linksys wireless G. If it is a problem with the wirless modem n the computer--built in--would using a wireless G card plugged into the computer trouble shoot that? If it worked and did not have the problem then it would be a hardware issue with myinternal wireless card? Thanks. J )</font>
You are on the right track. If the problem is not resolved until a reboot of your computer, I would be looking at either an internal hardware issue (NIC) or even possibly a software issue. Before replacing the card see if there has been a software update or conflict (unlikely). You can check for hardware software updates when (if) you use "Windows Update" and look under the Hardware option. (Just saw that I have an update for my wired NIC.) There could also be a problem with compatibility issue between the laptop NIC hardware/software. (That was an issue that I had until I had to replace the router.)
The last time I checked I could get an inexpensive router for about the same price as a PCMIA NIC
Goodluck
Kurt
/ This page cannot be displayed--??? #12
Try going to a spot that has a WiFi or a friends house that has a wireless conection. If you work fine there with no issues then you know it is your router.
If you do have an issue then you know it is either your wireless card or Windows droping your connection.
If it is the machine or card try to borrow someones PMCIA wireless car 7 use that to test - that willbe one more thing to eliminate for the issue.
That should narrow it down for you.
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
