third spool available on mid mounted dual SCV
   / third spool available on mid mounted dual SCV
kennyd said:
MJ, Don't sweat the wheels! Just jack the tractor up just enough hold the weight of the tractor, then remove the bolts-then just roll the wheel away. There is no need to lift the wheel using this method. Once the wheel is off, continue to jack the tractor up to the needed height and put a jack stand under it.
Good idea Kenny. I'll admit I have a nasty tendency to over complicate things. Plus not building a jack adapter will save me money for other things I'd rather build. I need to look the instructions over more carefully and see if I really need to remove the wheel per the directions. I can see the need to remove the fender, and I suspect the wheel needs to come off to get the fender off.
Thanks again for for a fresh perspective.
   / third spool available on mid mounted dual SCV #12
While I think you "could" do the job with the wheel in place, it will be MUCH easier to get it out of the way. On my 4110, there was an access panel in the fender behind the wheel to get to the SCV...having the wheel in place would have been self-induced torture! Just take it off and don't worry about it:D
Kenny:
Any thoughts on what the rear wheel and tire of a 4200 weighs? I have R4's and the rear tire is about 36" in diameter. The tires are NOT filled and I do NOT have wheel weights either.
   / third spool available on mid mounted dual SCV #14
My ballpark guess is 125lbs or so...very manageable using the method I described earlier. Even filled tires are easily managed using that method.
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
