Third Function Valve
/ Third Function Valve #1
Steelworker17
Yanmar SA424
Hi all,
Is there a made to fit third function valve kit for an SA424? There's a lot out there but which one will fit without too much modification?
/ Third Function Valve #2
Can anyone answer this question? I'm thinking of a front grapple and would like to hear about someone's experience with a third function install.
/ Third Function Valve #3
WR Long makes some nice kits. It should not be a problem installing on your Yanmar.
There is two basic ways of getting it done. One is a diverter valve. This would work off of your curl function on your loader valve. Push the button and then your curl works the grapple. Release and curl cylinders work again.
Second way is true 3rd function. This uses the power beyond port from your loader valve. This type will have a rocker switch that will open and close the grapple.
Here is a link to WR Long website.
/ Third Function Valve #4
Yanmar now has a third function kit for the SA series tractors
  • 0F052-EN0050_SA 3rd Function.pdf
/ Third Function Valve #6
/ Third Function Valve #7
The link doesn't work unless you allow them to control your computer. :poop:
That is strange. It worked for me on different computers. One needs to be downloaded. It is a PDF. The other is just a link to a website.
Is anybody else having a issue with these links?
/ Third Function Valve #8
Works just fine here. Goes straight to the WR Long's page.
The other, is just the PDF file about third function on a Yanmar.
/ Third Function Valve #9
Thanks Ptsg!
/ Third Function Valve #10
I'm running IE-11 with scam protection software. I don't auto load PDF files--It's too dangerous. All I get from that link is a blank screen so they must be trying load other PC grabbing software too. The kit is available elsewhere. I don't load special software for info-grabbing sites. :rolleyes:
/ Third Function Valve #11
Definitely do not load anything. It is a simple link so if it is redirecting you somewhere else you have a virus.
/ Third Function Valve #12
I have WR Long set up as true third function. The dealer installed it along with my Land Pride SGC1560 grapple. It is sandwiched into this well protected location.
/ Third Function Valve #14
At my dealer couple days ago.
He said kit for the sa424 was around $550.
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2024 JCB 35Z (A60462)
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
