Third Function Problem
/ Third Function Problem #1
wwenzel
2002 Kubota L4310
Hi folks...new user here. A few years back I installed a woods front end loader on my Kubota and had a third function installed hoping that one day I could afford a grapple. Well I finally bought an EA grapple. When I hooked up the grapple it operates as intended but the lid closes slowly and doesn't seem to have the clamping pressure it should. I'm assuming something with the valve but I'm hoping you good folks may have ideas and suggested fix. Thanks!
/ Third Function Problem #2
What's your flow and what is the required flow for the grapple? Are you using an extra reservoir (may also be short of fluid if you just filled the lines and rams).
/ Third Function Problem #3
Have you operated / cycled it enough times to purge all the air out of the line & cylinders? If you haven't you may need to fully cycle it many times to get all the air out... then check you fluid level...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
2025 DOWN 2 EARTH GOOSENECK TRAILER (A65054)
2025 DOWN 2 EARTH...
2012 Peterbilt 337 S/A 17ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
Conveyor Belt (A64194)
