Thinking about getting 4520 or 4720
/ Thinking about getting 4520 or 4720 #21
Yes you can operate the mid and rear PTO's at the same time but the seat switch, if de-activated, will shut off the PTO's. The seat switch will also shut off any rear PTO implement if de-activated. Then for rear PTO implements you can run the rear PTO separately. The rear PTO can be engaged from outside the tractor. To do this you need to engage the parking brake. From outside the tractor you can start the tractor, adjust engine speed and engage the rear PTO. This only works when the rear PTO is engaged and not when both PTO's are engaged with the yellow selector handle.
Kubota L175 Tractor (A62613)
Kubota L175...
2015 Freightliner (A64119)
2015 Freightliner...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
227 (A64278)
227 (A64278)
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
