Thinking about buying a Tig welder, Everlast?
   / Thinking about buying a Tig welder, Everlast? #21
Oh you want a water cooler! Without a water cooler the Tig torch will be huge! No body wants to use a club when Tig welding! A water cooled torch is so much smaller. Maybe Mark has a picture where you can compare the size difference between an air cooled torch, and a water cooled torch.
Ha ha ha. Finesse with sledge hammer!
   / Thinking about buying a Tig welder, Everlast? #22
I would take him a picture of the two torches I have, but one is a 150-amp air cooled, the other is a 300-amp water cooled, they're very close to the same size.
   / Thinking about buying a Tig welder, Everlast? #23
Being a water cooled torch, doesn't necessarily change the size. It depends upon the amperage you are desiring to operate and what the torch is rated for. A water cooled WP 18 is the same size as the air cooled WP26 and the smaller sized air cooled WP 9 is the same size as a water cooled WP 20. The difference is in the maximum amp rating. A WP 20 water cooled torch is typically a max of 250 amps DC. A WP 18 water cooled torch is typically around 350 DC... on both torches AC ratings are about 20% lower.
Yes the arc quality is good on the units. It won't weld 6010 but all others are great to weld with typically.
Here's a video on last years PT 185 model. It has changed a little for the 2013 models of course, but the unit is very similar as the internals are still the basic same ones with a few circuits added.
PowerTig 185 Micro Welder- AC/DC TIG Inverter welder- GTAW- Everlast PowerTig Welder - YouTube
   / Thinking about buying a Tig welder, Everlast? #24
Here is a picture of the only two Tig torches I have left. I had to look it up, the lower torch is a WP-20 that came on my Dynasty 300, it is 250-amp torch, but I have welded with it at 300-amps several times. The upper torch is a WeldCraft 150-amp air cooled torch.
I leave the north south wheel on the WP-20 torch all the time. The torch is almost to small for my hand. The wheel helps me rock the torch back and forth for walking the cup.
   / Thinking about buying a Tig welder, Everlast? #25
Never saw a water cooled torch as large as the same amps in an Air Cooled. At 250 amps, the Air Cooled 26 style is 3x larger than the 20 Style water cooled.. > Miller Diversions..Look close. At 180 amps the built in non adjustable post flow runs from 25 - 35 seconds variably after each arc.( Real Gas Hog )..Can't stick weld or remove the torch..?? Just look at all options before buying a Diversion. Nice little unit I'm not bashing. There's just more out there than a nice looking box. Any will work, just get you money's worth..
2012 International (A59230)
2012 International...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
378721 (A54865)
378721 (A54865)
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
