Thinking about buying a Tig welder, Everlast?
/ Thinking about buying a Tig welder, Everlast? #11
The Miller Diversion 180 might just be the ticket for JAS! Just because of that little book that comes with it.
Diversion
/ Thinking about buying a Tig welder, Everlast? #12
Yeah I saw that. I hope it has lots of pictures, no big words, and some coloring sheets would be the ticket! If they throw in the crayons, shoot that's first class :) :) !!!
/ Thinking about buying a Tig welder, Everlast? #14
I've welded on a few buckets, but don't remember writing any books about it.;)
/ Thinking about buying a Tig welder, Everlast? #16
The 200 has an outlet on the back set up for our 240V water cooler. Right now it is not switched, but the cooler has it's own switch.
It's a good starter welder, but for people with lighter duty needs, and are considering a Diversion, the PowerTIG 185 offers much more for much less. 185 amps @ 35% duty cycle for starters. For comparison check out the duty cycle on the Diversion :O ) It also offers AC frequency and balance control. It offers stick weld function and STANDARD Dinse type connectors. It also now has post flow control. And it's much smaller and a little lighter and a LOT cheaper. 849.00.
/ Thinking about buying a Tig welder, Everlast? #17
Mark do Everlast's Tig machines on SMAW have the same quality arc as my PowerArc 200?
I love my Dynasty 300 for Tig welding, but boy does it suck for SMAW, the PowerArc 200 will run circles around the Dynasty! :confused3:
/ Thinking about buying a Tig welder, Everlast? #19
Interested! I do love versatility :) got any welds to show???
/ Thinking about buying a Tig welder, Everlast? #20
Oh you want a water cooler! Without a water cooler the Tig torch will be huge! No body wants to use a club when Tig welding! A water cooled torch is so much smaller. Maybe Mark has a picture where you can compare the size difference between an air cooled torch, and a water cooled torch.
Kubota B2301 (A53317)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A60736)
TOYOTA 8FGCU30...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
