Thinking about a snowblower, tractor mount
/ Thinking about a snowblower, tractor mount #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, There is a Farm King 60" snowblower W/O shaft. What do you think it is worth?
Is Farm King a good one?
It was on a Yanmar. The shaft may have been sold with the tractor. They mentioned $975.
What would you think, I'm thinking $450? Would I be able to arrange a shaft for $100 ?
Thankyou
Richard
/ Thinking about a snowblower, tractor mount #2
I picked up a Farm King 60" snow blower w/shaft last spring for $500 Seems the prices are about half at the end of the snow season as they are in the fall. The s/b I bought was in good/excelent condition with not too much use. Farm King is a good home owner/utility grade unit. You should be able to pick up a PTO shaft for <$100 at most of the farm stores.
Ditech
/ Thinking about a snowblower, tractor mount #3
If the blower is in decent shape anything under a grand is a good price. The auger should turn freely and when you turn it the 2nd stage fan/auger should pick up a nickel, (quick and easy way to check for auger and drum wear). Check that the gear box is full of oil and no oil leaks.
Thanks for the feedback. I haven't seen this one in person yet. I'd like to have the shaft with the blower rather than hunt one down. There will be a difference in spline and such? There might be more to be had between now and winter next.
Greetings, Will it be simple to replace the shaft or will there be a hassle with metirc fittings or making a fit? Thankyou
Richard
/ Thinking about a snowblower, tractor mount #6
Guys,
Just went out and checked my Farm King s/b the gear box has open gears that dont run in oil. The PTO shaft connects to either a 1.25" or 1.375 round shaft with a .25" key in it. Should be easy to get a pre-made PTO shaft that will bolt right on.
Ditech-
Greetings, If I can get it for $450 I'll have time to hunt for a shaft or get one configured for it. Does that make sense?
Richard
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
(11) HAND SANITIZER STATIONS (A60736)
(11) HAND...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
