Thinking about a Mini-X ... ?
/ Thinking about a Mini-X ... ?
Fit on the trailer. - you plan on moving often or are you thinking of hiring out? If the latter, check prices on insurance first, you may quickly rethink that plan.
Nope, neither.
But knowing the trucking industry quite well ... Trying to schedule delivery when I'm home, and they could deliver would be extremely tricky!
/ Thinking about a Mini-X ... ? #43
So ... Would it be fair to say that a TLB and Mini-X would have the same digging power, if they were the same weight, (weight is the anchor the bucket pulls against?) but the Mini-X has much faster hydraulic flow, so can not only cycle faster, but can combine actions better?
I'm late here and didn't read all replies, but just to flag this one:
No, a mini-ex that is the same total weight as your compact TLB will dig WAY better and harder. And yes, much faster too. Tractor backhoes are just weaker, period. A tractor frame is not built strong enough to handle the full reaction forces of a comparably strong backhoe.
I have rented mini-ex's a few times, and then I bought my Kioti CK3510 with backhoe, and was pretty dissapointed with how weak it is. It can barely dig through tree roots, takes forever to get a stump out. Almost not worth even trying. And my Kioti is nearly 5000lbs with the front loader and backhoe mounted, actually sometimes I fill the front loader bucket with soil for another 1000lbs or so, and the backhoe still just kinda sucks. Better than a hand shovel, though.
/ Thinking about a Mini-X ... ? #44
I chose a Mini Ex and a Stand On Skid, over a TLB for a few reasons
Small Lot so turning a TLB around would prove troublesome in many cases.
Dig a Pile, then 180 degree turn to move it. Or jump on the Mini Skid to move it?
360 degree of movement, not 35-45 degree with a Back Hoe. Not dirt so much as Branches, Stones, Outboard Motors, whatever.
I can tow a Trailer and Load Dirt with 1 Machine.
If I had a Tractor, I would use the 3 point hitch, more than the Hoe. Every time I need a Hoe, I would be switching, then switching back shortly.
/ Thinking about a Mini-X ... ? #45
when I moved to the acerage, I purchased a Kioti CK20 or 224 anyway also got the backhoe, rough and finish mower and for some reason unknown a rear snowblower, used the tractor maybe 30 hours cut grass and dug roots and trenches for gas and water, it was slow, not comfertable and basically a pain in the neck first snow fall
I had a skidsteer but next year picked up a bobcat E32, now this runs circles around the tractor, I run augers, home made trenching buckets, 3 fot rake, tilt bucket and a breaker, its been a great machine yes its slow traveling any distance but runs circles around the tractor
the tractor was retired into the container figured I may need it, that was 8 years ago
I'm not really worried about tight spaces ... This is my 16 acres, mostly all open ...
My backyard, the creek is just past the tractor ...
The front yard ...
By little TLB has 150° swing with the BH ..
I see this, which seems like a lot more machine , but a bit past my proposed budget ... It looks like Hitachi actually makes the smaller Deere's ... But it's also quite about farther away ... Pushing 450 miles, one way!
/ Thinking about a Mini-X ... ? #49
That's a nice machine 1350 hours and a decent price. It looks good and clean too. 12" tracks, and 5400 lbs its a size you can do some work with. Richie specs https://www.ritchiespecs.com/model/hitachi-zx26u-5-mini-excavator
The only drawback is a 12" bucket - good for trenching but at that price you can add another one.
Which leads me to another question ... Can I put a Deere bucket on a Kubota or Bobcat?
What is a good universal sized bucket for these 2-2.5 ton excavators?
/ Thinking about a Mini-X ... ? #51
On buckets it depends; if its a quick change type, no as each brand has their own bucket QA setup. As for an ideal size, I feel 18" is a nice all around bucket width.
On the ZX26U they have there QA system Hitachi ZX26U Digging Bucket - 18" / 450mm
But you can buy or have the flanges cut and get a standard bucket and weld them on too.
If its not a QA setup - then its the pin diameter and stick width are the key dimensions to look for.
I was thinking of challenging testing my welding skills, and build a converter bracket to put some of my Massey Ferguson attachments on it ...
/ Thinking about a Mini-X ... ? #53
If it’s a pinned bucket maybe. If it’s quick attach almost definitely not. Unlike skid steers excavator buckets have pretty much zero standardization. Even the same brand manufacture only shares maybe 2 size classes per bucket.
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
CAT 330DL Excavator Grapple (A68134)
CAT 330DL...
PALLET OF MISC FLANGES/BOLTS (A67714)
PALLET OF MISC...
2015 JLG G12-55A TELEHANDLER (A67714)
2015 JLG G12-55A...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
