Think I could use nails instead of screws on a kids playset?
   / Think I could use nails instead of screws on a kids playset? #51
That sounds like the best solution, and what I would do. I love torx head screws. I also try to use self drilling, or 'no drill' type screws for treated lumber. That helps reduce splitting with screws close to the ends of the boards.
Good point. I have switched to those as well. A little more spendy, but worth it for the reduced aggrevation.
Aaron Z
   / Think I could use nails instead of screws on a kids playset? #52
As far as I'm concerned the only nail that should be made is a finish nail. For everything else I'm using some sort of screw, preferably with a torx head or a bolt hex head.
As far as stripped phillips heads, I've found that using an impact driver greatly reduces the amount of those.
   / Think I could use nails instead of screws on a kids playset? #53
I think the kids and use will determine how durable you need to build it. I'd screw it--I was a little gorilla, and would shake, whittle, climb, swing, hammer, pull and push anything I could get my hands on. Even plain old swinging will work the joints loose with nails.
   / Think I could use nails instead of screws on a kids playset? #54
Screws for everything for me.I did use a nail gun for some barn siding and that worked great.
   / Think I could use nails instead of screws on a kids playset? #55
If you are using pressure treated lumber ( which you should ) You need to use the proper zink platted screws.
MrC.
   / Think I could use nails instead of screws on a kids playset? #56
I always use screws when I build things because of more holding.
2020 DRAGON ESP...
2017 Chevrolet Silverado Pickup Truck (A55973)
2017 Chevrolet...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
