Think I could use nails instead of screws on a kids playset?
   / Think I could use nails instead of screws on a kids playset? #51
That sounds like the best solution, and what I would do. I love torx head screws. I also try to use self drilling, or 'no drill' type screws for treated lumber. That helps reduce splitting with screws close to the ends of the boards.
Good point. I have switched to those as well. A little more spendy, but worth it for the reduced aggrevation.
Aaron Z
   / Think I could use nails instead of screws on a kids playset? #52
As far as I'm concerned the only nail that should be made is a finish nail. For everything else I'm using some sort of screw, preferably with a torx head or a bolt hex head.
As far as stripped phillips heads, I've found that using an impact driver greatly reduces the amount of those.
   / Think I could use nails instead of screws on a kids playset? #53
I think the kids and use will determine how durable you need to build it. I'd screw it--I was a little gorilla, and would shake, whittle, climb, swing, hammer, pull and push anything I could get my hands on. Even plain old swinging will work the joints loose with nails.
   / Think I could use nails instead of screws on a kids playset? #54
Screws for everything for me.I did use a nail gun for some barn siding and that worked great.
   / Think I could use nails instead of screws on a kids playset? #55
If you are using pressure treated lumber ( which you should ) You need to use the proper zink platted screws.
MrC.
   / Think I could use nails instead of screws on a kids playset? #56
I always use screws when I build things because of more holding.
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
Hose Reel (A55787)
Hose Reel (A55787)
Kubota M5-111 (A53317)
2003 Big Tex 10PI...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
