The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
I hesitate to re-open the discussion about grapple width but the previous discussion has produced more heat than light. I'm about to order a Wicked root grapple for my Branson 3725. It'll be dual lid. Uses will be to pull up and transport brush (poison oak and coyotebrush), and move logs and rounds. I may do some raking of forest debris but not much as our land's too steep. The weight difference between the widths is in the tens of pounds so that's not a factor. It seems like a wider grapple would be able to grab more brush and rounds than a narrower one. For logs I think width won't matter much. I'm mostly considering the 60" and 66" models. My bucket's 67" across the inside so I'm already used to that width. The 66" has the lids farther apart than the smaller models, what practical difference does that make?
I do not have a really strong argument for one vs. the other, so I always leave it up to the customer in the end. BUT, I'll offer some insight since you asked.
For tasks listed, I like the 60" for maneuverability in the woods. Also, if you want to push up roots, rocks or anything else embedded in the soil, you'll be able to push the smaller one easier because it has less tines.
Travis
The 60" will grab just as much brush as a larger one. This is actually a 60" single on snowback's 2538 Mahindra, but who could tell? :laughing:
Large logs will not be an issue either. This is a 60" Dual Lid on a Kioti NX5510.
Oh, a couple of pics for comparison....because aren't pics great?
60" Dual Lid on a Kubota L4060
66" Dual Lid on a Kubota L3240
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,822
The 55 or 60 will be easier to maneuver and for brush and logs a single lid will do the same job but will cost and weigh less.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,823
As far as brush goes, you won't see a difference in capability. The biggest advantage of a wider width is when picking up loose item like firewood, rounds, small stumps etc. Items like that. For brush, it won't matter.
i-69nj7Jc
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,824
Pushing over a few trees is no big deal. Clearing land is about the hardest thing you can do to equipment and a tractor isn't up to the task.
Totally agree with all but the last few words of this quote. ("A tractor isn't up to the task")
Just so other people who haven't tried it don't get swayed away from their decision to try it, a tractor is DEFINITELY up to the task of land clearing.
It's just not the best tool for the job, and a lot more delicacy is required. Is a skidsteer, excavator, or dozer better? Yes.
Is a tractor up to the task? Yes.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,825
The key words I heard were "pull up". More often than not, the corners of a grapple are used to get under and uproot stubborn brush and saplings. Used thusly, a wide grapple will twist the front end loader and even lift the opposite rear wheel off the ground on occasion. For tough uprooting, narrower will be more effective and easier on the equipment, in my opinion.
We have a 72-inch single lid which has performed valiantly on our 55 horse Mahindra. But if I had it to do over again, I would go no wider than the FEL. No matter what size you get however, you will be delighted.
A few examples. I'm sure I have more if I really dug(pun). :laughing:
Travis
Exhibit A Kubota M6-141
Exhibit B Kubota M6-141
Exhibit C Kubota M6-141
Exhibit D Kubota L6060(amplified on purpose)
Exhibit E Eric's famous Kioti NX6010.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,827
Finally got to use my new 55" grapple. While not as impressive as what some of you big boys are doing, it helped me move a lot of stumps and brush to my burn pit. Some of the stumps were heavy enough to almost pick up the backend of the tractor, even with the backhoe and wheel weights. I won't complain about doing that all day and not breaking a sweat! :)
I am as impressed with what the BX23S is accomplishing there as I am with your taste in grapples(that's a LOT)!! :applause:
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,829
Which model grapple is this, Ted? It looks like it has wings extending beyond the tines and a brush guard built in. That looks like a good compromise. The wings keep the brush off of the tractor and the tines are only the width of the FEL to keep the work centered. To get the extra width to protect the tractor is one of the main reasons I chose a 72 inch.
523822d1462818725-wicked-root-debris-grapple-resized952016050995142038s-jpg
It's our Wicked Utility Grapple for tractors up to 125hp. Ted built the one shown 96" wide for our Kubota M6-141, but, after using it, wouldn't recommend larger than an 84".
TOO wide for most applications, but we'd probably still build one if a customer really wanted it!!
Travis
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
New Holland WorkMaster 37 (A53317)
New Holland...
John Deere 1025R (A53317)
John Deere 1025R...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2017 Genie GTH-636 (A53317)
2017 Genie GTH-636...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
