The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,811
Putting your operating ability or land clearing experience aside why would you buy a tractor. A backhoe or CTL would be a way better choice.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,812
Re: The WICKED Root & Debris GRAPPLE!!!!!!!
If I was solely aiming to clear land I would but I have lots of other uses normal tractor uses also, both for myself fan for hire. In a word, versatility.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,813
The trees I have won't be nearly that hard to deal with. The ground in that video is dry and hard too, mine has been saturated for the last year. A 7060 will have a bit more leverage and traction too. I'll have a full set of weights and the big front tires and have them loaded also, and loaded cast rears too:)
I actually thought his tractor was a 7060 when I posted the video, but he sent me a message correcting it!!
Being a 5660 makes it a little more impressive! :eek:
Travis
Here's another M7060 playing hide the grapple with a 73" Dual Lid Wicked one!
Hugh from Georgia posted this pics in the EA Channel Group. He has our lightweight 50" Single Lid Wicked Grapple pinned onto his Kubota LA364 loader.
Travis
"Cleaning up after Irma using my Kubota B2920 and EA Grapple with EA Box Blade on the back for weight. The trunk is 32+ inches in diameter so the logs weigh around 400 lbs a piece. No way I could have moved them without the grapple."
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,816
Hmmmm....M7060....
Does this make you want one even more? :laughing:
Travis
Bradd from NY...M7060 and 73" Single Lid Wicked Grapple!
How bout this? Bradd always uses the grapple to rip up scrub when bush hogging with his EA Brush Cutter. Pulling it up by the roots keeps the junk from growing back!
Hide-a-Grapple!
OOOHH YEA! Now I'm thinkin a 55" single lid would fit all my needs. I'll order soon!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,817
That grapple will do great. Post some pictures when you get it. Good choice.
Derrick from Michigan posted these pics in the EA Channel Group over the weekend.
It's a little unconventional, but I can't get enough!! :eek:
Kubota L6060 with a 73" Dual Lid Wicked Grapple. Oh, the little Honda 4518 was released unharmed. :laughing:
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,820
I hesitate to re-open the discussion about grapple width but the previous discussion has produced more heat than light. I'm about to order a Wicked root grapple for my Branson 3725. It'll be dual lid. Uses will be to pull up and transport brush (poison oak and coyotebrush), and move logs and rounds. I may do some raking of forest debris but not much as our land's too steep. The weight difference between the widths is in the tens of pounds so that's not a factor. It seems like a wider grapple would be able to grab more brush and rounds than a narrower one. For logs I think width won't matter much. I'm mostly considering the 60" and 66" models. My bucket's 67" across the inside so I'm already used to that width. The 66" has the lids farther apart than the smaller models, what practical difference does that make?
CFG Industrial MX15RX (A56469)
CFG Industrial...
2005 Kubota ZD21F 60in Zero Turn Commercial Mower (A55851)
2005 Kubota ZD21F...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
Sellick S60 (A53317)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
