The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,051
Yep. The best grapple is any grapple you can get your hands on.
Exactly on point! We all seem to WAY over analyze the minor differences in grapples. ANY grapple is 100 times better than a bucket. Even a bolt on thumb makes your equipment many times more useful.
There are times where a dual lid will be better for the job at hand, but not necessary.
You can see in this pic how with a single lid, you would be more apt to lose part of the load.
With a single lid of less width, the logs would have teeter tottered up at the ends more.
If the logs had been piled nice and straight, this wouldn’t have mattered.
In these pics below, you can really see why the wider dual lid will be able to hold more in certain situations.
Two trips turned into one by being able to hold double.
There are very few instances where the narrow single lid won’t “work” for the job, regardless if it takes a little extra time is a little less efficient. At the end of the day it’s not that big of a deal.
My biggest concern, early on, was whether the the clamping force was adequate: it is- I've got a picture around here somewhere that was taken with my grapple clamping down on two conjoined stumps, dangling down from the grapple (clearly the full weight was being held by the clamping force).
:scratchchin: I have that pic around here somewhere, too...
Ah, here it is! :eek:
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,053
Yep, any grapple is better than a bucket. To defend my narrow single lid I’ll point out that it costs less, lifts more, is easier to maneuver, digs better and also that the number of times that you’ll be carrying two stumps at once is a small fraction of grappling time. I know you guys with dual lids are always concerned about balancing a wide load with a single but it really is not an issue. Can you balance a golf club with just one hand? Remember that the dual lid has its origin as a construction implement for a skid steer designed to pick up lots of small debris at job sites. Think also about huge excavators that never use anything but narrow single lid grapples to tear out and move full size trees. Apparently they don’t have any trouble with wide loads.
Again, any grapple is better than no grapple. Each to his own.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,054
Have YOU ever picked-up a load/log that was so long/heavy that when you got off the tractor the rear tires came off the ground???!!! Neither have I (one tire perhaps but not both ;+)... BE CAREFUL... IMG_6339.JPG
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,055
Have YOU ever picked-up a load/log that was so long/heavy that when you got off the tractor the rear tires came off the ground???!!! Neither have I (one tire perhaps but not both ;+)... BE CAREFUL... View attachment 533930
Absolutely! But not since filling my rear tires.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,056
Got to hand it to you Lad... Seems you do a lot with that rig... Love the enthusiasm... This is NOT a competition... JUST a comparison... PLEASE be safe...
Why do you think unbalanced or uneven loads are better handled by two lids? Do you need two thumbs to hold an uneven or unbalanced object in your hand?
As a double-lid grapple owner/user I may look at this double-vs-single lid-thing perhaps a little differently than you/those with a single-lid grapple... I understand also that our purpose/applications may be very different... According to what I have seen you post/describe, apparently you think of/use your single-lid as a thumb... NOTE: My loader/double-lids are extensions of my arms/HANDS, each lid acting as a HAND vs thumb... My lids are very near the edges of my grapple and yours/most single-lids are usually centered... I VERY RARELY approach a load/log/pile of brush/debris/root/bush/hole/mound/rut/etc. that is centered... I am OFTEN/USUALLY tackling/approaching things that I want to pick-up/work-on from an angle, reaching over/around a corner, barely able to grab from the side, and I use the edges/corners/left and right lids as HANDS to make initial contact, nudge, grasp/pinch in order to move/relocate pull into more effective working-range, help to get centered... Quite often after making this initial contact/pick from an odd angle/off to the side, I realize that I have the load well-enough (albeit unbalanced) to carry it safely/conveniently/further/perhaps to the intended destination... Also, my double lids/two hands allow me to grasp smaller items and/or piles of smaller 'clean-up' debris/brush... This issue has been discussed/debated ad-nauseam... Just wanted to share what I believe may be a different perspective (2 hands vs 1 thumb) since I have not seen/heard this comparison... There is no substitute for experience and I know that I could not do with a single/central-lid (thumb) what I currently do with two lids (hands)/one on each side of the grapple/loader (arm/s)... YES, any grapple is better than no grapple, but I need/fully utilize the dexterity that two hands/lids provide for the wide variety of work that I have to do with my tractor/loader/grapple... IMG_6285.JPGLongHeavyLoad.JPG
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,057
As a double-lid grapple owner/user I may look at this double-vs-single lid-thing perhaps a little differently than you/those with a single-lid grapple... I understand also that our purpose/applications may be very different... According to what I have seen you post/describe, apparently you think of/use your single-lid as a thumb... NOTE: My loader/double-lids are extensions of my arms/HANDS, each lid acting as a HAND vs thumb... My lids are very near the edges of my grapple and yours/most single-lids are usually centered... I VERY RARELY approach a load/log/pile of brush/debris/root/bush/hole/mound/rut/etc. that is centered... I am OFTEN/USUALLY tackling/approaching things that I want to pick-up/work-on from an angle, reaching over/around a corner, barely able to grab from the side, and I use the edges/corners/left and right lids as HANDS to make initial contact, nudge, grasp/pinch in order to move/relocate pull into more effective working-range, help to get centered... Quite often after making this initial contact/pick from an odd angle/off to the side, I realize that I have the load well-enough (albeit unbalanced) to carry it safely/conveniently/further/perhaps to the intended destination... Also, my double lids/two hands allow me to grasp smaller items and/or piles of smaller 'clean-up' debris/brush... This issue has been discussed/debated ad-nauseam... Just wanted to share what I believe may be a different perspective (2 hands vs 1 thumb) since I have not seen/heard this comparison... There is no substitute for experience and I know that I could not do with a single/central-lid (thumb) what I currently do with two lids (hands)/one on each side of the grapple/loader (arm/s)... YES, any grapple is better than no grapple, but I need/fully utilize the dexterity that two hands/lids provide for the wide variety of work that I have to do with my tractor/loader/grapple... View attachment 534101View attachment 534102
Best argument i've heard so far for getting the dual lid for general purpose work.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,058
Can't let a lid polemic pass without jumpin' in. My ranch hand pointed out that when he chomps down on a load of Yaupon with the single lid on our 72" Wicked, the Yaupon itself tightly squeezes the whole wad together securely.
Here he is transporting a batch a quarter of a mile without losing any. The red sunshade of the tractor is barely visible above the massive bundle and a splash of daylight can be glimpsed below.
5D6NmeczkO0vEl-gjwMeLEPQIDm9iKFhOwumsFO5rQysJ2lExWWz_MVD04abQhwVfZMvGSZZqmsVY2LQ43ofpxKf6DdOrhk85N3h6N6YMXE03hODQ4iA7Ni9uT-A3NLb-HjSNtTqER_x41wTxcIdJdDYtbqjOOE0d2fH-zVu99InXeeopajmEoD80o2je4HJUTM8pGTM6TVq5iVA5Q5w35_A38GhoLr_S6Vu9uSNzBXCSxtplb759_8iWGwYjKABpNYeAwMCPm0iVnJEytneNKvKxOardO3_Rso8dYWzpJqk-JNvkdmaKsREKWTWDfs6U_Y6jfv94U6vbzCgREGfG6sZUf4yLUif86KDCyE1SqrqA4sOIOXv4AO7JtCvRgI0330fisQVNntSZFSp7gD5MYqDwK0skzVDlFt5lBjWXk0iNp1zhWxQ_QHWLZwj1x_hCLGsFxmYXEwwgqgxDVvA-kZoqB0i9Bnyq5WuSFov3Eavs2g76il89T57yFH1c_8XjaOP3_-2gliyx1K4hhKtnKEwFMyh2Le-6cRpKNUFg4SYEq-U5ZnCIighvcS3kUK4NfHCPfGMp8_CeEKQnnucs3gjtmPKr4et6LYy5BjU=w877-h654-no
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,059
So ........ same thing doesn’t happen with a dual lid? I’ve got a dual lid 84” Blue Diamond and a single lid 73” EA. Both work well with branches, etc.
The key issue is your “individual” needs and anyone looking into purchase of a grapple might review threads, like this one, to see what others with similar uses are doing. Then make the best deal and join the grapple nation.
Once you’ve made a decision, the “experts” will try to show why you made the “wrong” decision just to glorify themselves as self-appointed “gurus”. You just have to filter out the BS from the sound information.
Holy COW!! :eek: I assume he's transporting in reverse! :laughing:
Travis
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55314)
2020 Massey...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
Poly Fuel Tank with Electric Pump (A55852)
Poly Fuel Tank...
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
