The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,281
Re: The WICKED Root & Debris GRAPPLE!!!!!!!
Use of the skid steer is cheating. :) Tracked at that! If you pulled one of your lids would you even be able to tell the difference on either machine?:D
They're both double lids! How badly the CTL beats a tractor is sad. It'll significantly out push, out lift, and the visibility is so much better. The ability to push sideways is also nice. Tractor grapples don't do well in a tangled mess of brush with tons of radiator spears. I can straighten up such a mess pretty good with the CTL. The picture better represents the scale of that grapple. IMG_9425.JPG
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,282
They're both double lids! How badly the CTL beats a tractor is sad. It'll significantly out push, out lift, and the visibility is so much better. The ability to push sideways is also nice. Tractor grapples don't do well in a tangled mess of brush with tons of radiator spears. I can straighten up such a mess pretty good with the CTL. The picture better represents the scale of that grapple. View attachment 514512
The want is incredibly strong with this one.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,283
Better hope your wallet is incredibly strong as well...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,284
Will see in a couple weeks, just spent the weekend using a prime attachments tree puller and stacked far too many trees for a regular bucket to handle, grapple seems like the tool to use for moving trees once pulled.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,285
A grapple, yea. I was just meaning your wallet needs to be incredibly strong for a CTL and that big grapple above, especially if buying new...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,286
I think the pricing is within reason for a quality grapple.
I'm having trouble deciding between a 55" or 73" width for an M7060. I have decided I'd like the dual lid, however.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,287
Agreed, rented a 80hp 3100 lift CTL this weekend for tree pulling. Holy functional.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,288
Oh man, I was wantin me one of those SVL-75's!!! I agree, my wallet isn't strong enough. LOL
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,289
Pricing at EA? Most definitely. That big beast above? No clue what it costs, but the machine to run it isn't cheap. :)
Deciding wide or narrow I think really comes down to your operating environment. A wider grapple mainly just allows you to move larger piles of brush. The concept that a wider grapple will better support off balance loads better is a misconception that will make a tractor 'tippy' and put twisting forces on the loader that even if nothing bends or breaks, it will wear pins faster and require more maintenance. If you have no obstacles to navigate, no tight areas you need to reach into, and have large areas of brush to grub up and remove, go with a wider grapple. If you need to operate in tight quarters, need to grub brush roots from smaller areas without damaging as much surrounding sod, or want to do more precision work with it, get the narrower grapple.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,290
Why do you like the dual lid? Any experience using either single or dual? Ever heard a complaint by someone who has a single??
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
MASSAGE CHAIR (A58214)
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
