The Thumb
/ The Thumb #1
fruitcakesa
CavendishVT
M6040 JD 450C
/ The Thumb #2
I have the thumb. I bought it with two base plates. mounted one on my forks and one on the bucket so I could switch the thumb between them. (05 of my thumb use has been on the forks. Somewhere in my posts here is pics of my install. At least two other members also bought and are happy with the thumb.
/ The Thumb #3
I have one on my emax its great. Built well. I will get some pics.
/ The Thumb #4
I have had mine + a tooth-bar for quite a while;works great.Easy removal(bolted) if needed.Cleared a lot of rock and brush with mine.
/ The Thumb
Thanks George , Chief and NY for the pics and reviews.
George, how did you choose the size thumb to get with your forks. My forks are similar in size and shape to yours.
/ The Thumb #7
I ordered the 36" thumb. Pretty much a guess with a tape measure and where I was going to mount the base plate. Glad I didn't get the smaller ones.
/ The Thumb #8
another Thumb fan.. as you see in some of the pics I also had to stiffen up the top of my bucket.. initially tried to just bolt it to the top lip and quickly found it was not near stiff enough..IMG_0755.JPG
/ The Thumb #9
I asked around here a while ago and got very good reviews. I will be adding a Piranha bar and Thumb to my machine FEL this spring. It might actually work better with forks but I have bolt on forks and no SSQA on my tractor so removing the FEL is not a good option for me. George2615 has a great idea above.
/ The Thumb
I have to drag the forks out of the frozen snow so I can take them to my friends shop.
He will reinforce them where the mounting plate will attach.
/ The Thumb #11
/ The Thumb #12
I stopped by their shop and picked one up a few years ago. It's the best bang for your buck for such things. I use mine with forks constantly. I can grab a 16' log, lift it to working height, and cut firewood rounds off very quickly. It's been great. The cylinder is well matched for size and power.
/ The Thumb #13
/ The Thumb #14
Thanks guys, I think this is just what I have been looking for. Even better is they are about an hour south of me so I can hopefully save on the shipping and maybe a little cash discount. Now to decide on a 3rd function setup they aren't cheap.
/ The Thumb #15
To save money and simplify the install, I am going with a diverter valve set up off the curl circuit. I will not be able to curl and grab simultaneously but I can live with that...I think.
/ The Thumb #16
I have one and love it. I had a piece of 3/8 flat bar welded to the top edge of the bucket as reinforcement before bolting it on.
/ The Thumb #17
I have a Thumb, and like it fine. Does what I need. I had it on my regular fork attachment, with a slide-on mount. It worked OK, but not what I wanted. So I found another fork attachment and mounted the Thumb to that, and made it the dedicated "grapple unit". Pics show it on both fork attachments.grapple 3.JPGDSCF1308.JPG
Wagon Wheel End Table (A65583)
Wagon Wheel End...
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
MUD MIXING FRAC TANK (A65643)
MUD MIXING FRAC...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
