"The Thumb" Bucket Grapple questions
   / "The Thumb" Bucket Grapple questions #11
What brand & model grapple is that?
I've been looking at the Construction Attachments "root grapple" that prices out around $2000 for the 60". Always interested in checking out alternatives...
-Jeff
It is a WR Long. I just drop it down where the teeth just rip the soil and drive along until I get a mouthful then move it where I want it. The "V" in the bottom will catch and rip out saplings. If one slides through, I back up a bit and pop it out with the teeth or grab it and pull it out.
   / "The Thumb" Bucket Grapple questions #12
I have a Kubota L35 that I had a 4n1 bucket added. That thing has been a lifesaver! I have 20 acres, that I'm cleaning up from being clear cut about 8-10 years ago. I also just bought a new Kioti DK50SE w/CAB and FEL. I had them add the WR Long root grapple, which I know will be even better. I actually pick up the machine on the 16th. So from my point of view, if you can get that thumb or even a grapple, and you know you will have tons of things to move, it's worth the money.
   / "The Thumb" Bucket Grapple questions #13
Love my "Thumb" :thumbsup:
solid, inexpensive, does a great job for logs, firewood, mulch, brush. No need for a full width grapple for what I do...
I have seen someone mount 2 "thumbs" side by side...
   / "The Thumb" Bucket Grapple questions #14
Like Milton Burro I went the full grapple route. I got lots of scrub trees and blackberries to get out and want to leave the dirt. So far it works great. ANBO GR-M
   / "The Thumb" Bucket Grapple questions #15
I spent 4 hrs. trying to find a thread/info, and found this 5 year old thread on Google with a thumb grapple thing that will bolt on my L3400 bucket because I have an 8 year on going PITA. Seams like most people have more $$$ then I do and like the full size bucket grapple and don't need their bucket. I'm constantly moving (dirt) snow rocks stumps brush and logs with my bucket, but the biggest PITA I have is moving logs.
Now the way I see it, a full size grapple is NO good for moving Dirt and Snow, now if you got $$ and a quick disconnect bucket, that's find, but all I need is something to make it easier to grab a log, and easy to take off so I can move dirt, and if I had a thumb on my bucket, moving brush, stumps, rocks would just be that much easier. So this summer I'm hoping to buy one of these thumbs for my L3400 if there under a $1,000.00, and I'm hoping I can figure out how to run hydraulic lines, I suffer from Hydraulic Illiterate Syndrome or H.I.S. problem.
Here is a short video of a PITA
https://www.youtube.com/watch?v=eSmaPYsXSuM
   / "The Thumb" Bucket Grapple questions #16
It is actually quite simple.
You need a diverter valve so you can switch the curl flow into the grapple circuit.
You will then need some hoses and fittings and a switch for the solenoid diverter valve.
The way it works is like this. With the diverter plumbed correctly, and no voltage applied to the solenoid, the valves feeds the curl circuit using the joystick.
If you flip the switch and supply 12 v to the solenoid, the valve assembly will change the flow path so the grapple now is getting the flow and the joystick will control the grapple.
OR
You could also use a 3rd function valve and plumb it in the flow path, which is like this.
The FEL PB out will feed the input to the 3rd function valve , and the 3rd valve out port will pass the fluid to the rear into a remote valve or the 3pt. You will need some hoses and fittings and a switch to activate the grapple whenever needed. There is a hyd block there to help you route the hoses.
   / "The Thumb" Bucket Grapple questions #17
I think it is do-able for the $1000 or less. Diverter valve is $212, Maybe $50 bucks for fittings Myabe $20 for a switch, $160 bucks for hoses, The thumb for about $400. So what is that around $900.. I think you could do that.
   / "The Thumb" Bucket Grapple questions #18
With the Thumb, the top of your bucket will need to be reinforced... can you weld? Mine is WR Long that bolts to the side of the bucket... but it costs more. I got mine used for $350 (which is about the price of the Thumb)
The Thumb - Shop Online
   / "The Thumb" Bucket Grapple questions #20
OR
Plan A doesn't sound like the plan I want, I don't want to loose my bucket curl or lift control when applying thumb pressure. Plan B might be the plan I want, but not sure might need more input, like PB? I know I want a separate control stick to operate the thumb.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
Deere 35G (A53317)
Deere 35G (A53317)
John Deere 920 Grain Platform (A59814)
John Deere 920...
