The restoration of a Ford 445A w/ Gannon Scraper box
   / The restoration of a Ford 445A w/ Gannon Scraper box #11
Nice job, tractor and BB look great. What color paint is that?
   / The restoration of a Ford 445A w/ Gannon Scraper box #12
City Farmer,
This is a response I got from aircommuter regarding the paint on his Ford 445A
"The paint is Ford/NH part# M5771ASE2DS quart number. It works well with DuPont 8034S acrylic enamel thinner, 4oz to a quart. I painted the whole thing with gravity feed hvlp gun."
   / The restoration of a Ford 445A w/ Gannon Scraper box #13
I've seen many a liquid overhaul...
What he did looks to be a pro paint job. He either started out with a cream puff or he put a lot of effort into detail.
I worked in my father's shop starting when I was 10, we did both body and mechanical. I have painted about 30 cars. I have one to post that was painted entirely by my wife with a brush here in my home shop. (Tractor that is) Check out Garage Journal with my same user name, they have a place for albums. You can veiw the home shop and boat project. You are right about the prep work, I get carried away, while people are saying it's just a tractor I'm still sanding.
Here is just one picture of her brush paint job. I posted the rest under Case/IH
   / The restoration of a Ford 445A w/ Gannon Scraper box #16
"while people are saying it's just a tractor I'm still sanding. "
That's a good like right there.
Sure can not tell it was brush painted from the picture. The paint must have been mixed hot. I'd keep her around.
   / The restoration of a Ford 445A w/ Gannon Scraper box #17
Can I ask where you found the reduction drive starter? I'd like to get one for my 345C
I found the supplier on eBay, it is called Rare Electrical. It is also much easier to put in the back bolt.
   / The restoration of a Ford 445A w/ Gannon Scraper box #19
I didn't see it in this thread anywhere. What is a reduction starter drive?
It is a starter that has gear reduction inside which allowed auto makers to use a smaller flywheel for gaining a lower floorboard in the cars. The smaller flywheel created a lower ratio making the growing engine sizes and increasing compression ratios difficult to crank. Started by Chrysler. Now that system has been enhanced by adding a permanent magnet motor to the gear reduction starter so it can crank faster and with even more torque than before . The permanant magnet starters use tighter tolerances inside making the motor more efficent. Used on Case/ Cummins, Mercedes Benz, first now almost everone has them.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
LEINBACH 1R CULTIVATOR (A52708)
LEINBACH 1R...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
3" X 4" GAS POWERED WATER PUMP (A52708)
3" X 4" GAS...
2001 FREIGHTLINER FL70 (A58214)
2001 FREIGHTLINER...
