The restoration of a Ford 445A w/ Gannon Scraper box
   / The restoration of a Ford 445A w/ Gannon Scraper box #11
Nice job, tractor and BB look great. What color paint is that?
   / The restoration of a Ford 445A w/ Gannon Scraper box #12
City Farmer,
This is a response I got from aircommuter regarding the paint on his Ford 445A
"The paint is Ford/NH part# M5771ASE2DS quart number. It works well with DuPont 8034S acrylic enamel thinner, 4oz to a quart. I painted the whole thing with gravity feed hvlp gun."
   / The restoration of a Ford 445A w/ Gannon Scraper box #13
I've seen many a liquid overhaul...
What he did looks to be a pro paint job. He either started out with a cream puff or he put a lot of effort into detail.
I worked in my father's shop starting when I was 10, we did both body and mechanical. I have painted about 30 cars. I have one to post that was painted entirely by my wife with a brush here in my home shop. (Tractor that is) Check out Garage Journal with my same user name, they have a place for albums. You can veiw the home shop and boat project. You are right about the prep work, I get carried away, while people are saying it's just a tractor I'm still sanding.
Here is just one picture of her brush paint job. I posted the rest under Case/IH
   / The restoration of a Ford 445A w/ Gannon Scraper box #16
"while people are saying it's just a tractor I'm still sanding. "
That's a good like right there.
Sure can not tell it was brush painted from the picture. The paint must have been mixed hot. I'd keep her around.
   / The restoration of a Ford 445A w/ Gannon Scraper box #17
Can I ask where you found the reduction drive starter? I'd like to get one for my 345C
I found the supplier on eBay, it is called Rare Electrical. It is also much easier to put in the back bolt.
   / The restoration of a Ford 445A w/ Gannon Scraper box #19
I didn't see it in this thread anywhere. What is a reduction starter drive?
It is a starter that has gear reduction inside which allowed auto makers to use a smaller flywheel for gaining a lower floorboard in the cars. The smaller flywheel created a lower ratio making the growing engine sizes and increasing compression ratios difficult to crank. Started by Chrysler. Now that system has been enhanced by adding a permanent magnet motor to the gear reduction starter so it can crank faster and with even more torque than before . The permanant magnet starters use tighter tolerances inside making the motor more efficent. Used on Case/ Cummins, Mercedes Benz, first now almost everone has them.
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
NEW Fork Extensions (A59000)
NEW Fork...
More info coming soon! (A55787)
More info coming...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
2010 International Derrick Digger (A55973)
