The Log house Project begins........
   / The Log house Project begins........
Uncooperative boards got the welding clamp:
Now it needs to dry for a day:
These are pretty cool:
Or I might go old school:
   / The Log house Project begins........ #853
Old school would be nice too. I saw a cool door combination lock using steel plate cams and porcelain knobs the other day.
   / The Log house Project begins........ #854
Our latches throughout are all the type that have a lever that lifts the slide up over the catch.....We are regularly catching clothing or worse just bumping into the protrusion, and it hurts...Authentic, but it has it`s drawbacks Tony
   / The Log house Project begins........ #855
Mike... careful with that forge talk, it might mean more work for you
A door handle isnt too bad. Couple hours at most. Ive made some pretty nice ones out of railroad spikes...
   / The Log house Project begins........ #858
Ohhh no you don't FB...no more hobbies/projects for me
We will get you into the metal pounding business one day. :)
   / The Log house Project begins........ #859
Too many projects to do and skills to learn. Not enough lives.
hugs, Brandi
   / The Log house Project begins........ #860
Yep, the expanding glue. It holds well, is water activated which also means it's water proof, can be sanded and stained and the holding power on wood is fantastic.
Motor7, you are doing a great job on your place. Question, exactly which glue did you use? Can I get the brand name and the type? I usually use something like Liquid Nails, etc. that I get at the box stores and it sounds like what you use is substantially stronger. Thank you and keep up the good work! Stanley
2022 Kubota RTV-XG850 4x4 Utility Cart (A56857)
2022 Kubota...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
2014 International Derrick Digger Truck (A55973)
2014 International...
2024 Bobcat T770 Skid Steer (A57148)
2024 Bobcat T770...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
THREE POINT ATTACHMENT (A58216)
THREE POINT...
