The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,741
I dunno…. What did you hear?
Thats about 80 miles west of me.
I’m on the PA/DE border.
Bad situation yesterday. When I made my post there weren't a lot of details out and wasn't sure how close you were to the situation
   / The Life of a Custom Mowing contractor #1,742
Today was one of those days that’ll make a man out of you.
Was cutting hay in some drizzle, then this happened.
The vertical strut connecting the cutterbar to the mower chassis experienced “metal fatigue” and simply broke off.
Called Agriteer/Pottinger parts and they said thats a known problem area and there’s a replacement kit- “only” $631 per side for updated, beefed-up supports. Pottinger offering them to me for 50% off since they have had numerous failures. Service advises replacing both sides, especially since mine are the older/weaker version. Luckily the cutterbar is still ok and the driveshaft, although a little beat-up is probably going to be fine.
THEY have to install it to receive discount :rolleyes: of course. And at “only $150/hr. I guess I can’t complain too much.
Another view
Closeup of where the metal fatigue is
Prop shaft seems ok
Good luck with the repair/upgrade hope they get it done promptly and reasonably.
So it turns out the vertical prop shaft is toast. Splines are all carved up. Have to buy the whole assembly.
Bad day for HD.
Back at it today now that the rain has passed.
A little raking around 12 o'clock while East Penn pulls a load nearby.
And now some baling….
And some stacking to finish the day.
We’re in “beast mode” now. The weather has been good for a few days and finally getting into a good rhythm of raking & baling.
Finished the day by dropping another 25 acres.
   / The Life of a Custom Mowing contractor #1,748
Are you getting caught up on bale count at all? I recall you were finding yourself short this year compared to normal. Whatever "normal" is for weather these days.
Getting closer, yes.
Another reason my bale count is lower is because I increased my balers pressure from 85% last year to 95% this year. I was running a lower pressure last year because I was having twine failure. I tried a cheaper twine (Field Ready) and really paid the price. Lots of knot failures.
I am back to running the good stuff (Bridon) and will never run anything else again, but Bridon.
Anyway, higher pressure means more hay in each bale and heavier bales, but less of them.
I prefer to run this way. It’s more efficient to make 1800LB avg bales than 1700LB avg bales.
“Normal” weather around here is usually pretty tough weather to make hay. It’s either raining every 3-5 days, or very dry. We’ve had a pretty good stretch lately. About 8-9 days with no rain.
   / The Life of a Custom Mowing contractor #1,750
Is that only your mulch hay portion or also what you sell personally? If what you sell personally do you price accordingly?
2019 Bobcat T870 (A53317)
2019 Bobcat T870...
1808 (A57192)
1808 (A57192)
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
flooring (A55758)
flooring (A55758)
JOHN DEERE 333G SKID STEER (A52707)
JOHN DEERE 333G...
2022 Chevrolet Silverado LTD (A56858)
2022 Chevrolet...
