The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor
I like the way your cutter folds toward center past straight up when transporting on road. That type design relieves a lot of weight from right rear axle & wheel/tire
And it takes away the possibility that IF you forget to lock it in transportation mode, it wont fall outward.
Final baling day before the July monsoon hits. It was a good one.
Working by myself, I raked & baled 30+ acres and made 64 bales between 11AM and 5:00PM.
Well into the day, but heres a raking pic
And now a little baling
Had some scale issues, so into the monitor I went for a little more info/diagnostics.
In the back of the property now. Almost done.
In the back parallel to the River, to the right.
A few rafters on the river.
Tractor is getting pretty toasty. Time to clean the radiator.
300th bale. Last year at time, I was well past 500 bales. So I’m way behind.
Forecast looks horrible. Might be my last day of baling for a while.
   / The Life of a Custom Mowing contractor #1,504
A buddy sent me this mid day Sunday. I can't repeat the comments included in his text.😉
Part of it included "the monitor took out the back window as it flew past my head"!
He makes 900+ rounds a year by himself with occasional raking help. All on scattered fields in a 30 mile circle so he's well experienced. S hit definitely happens!
HD he's feeding cattle (haylage) and wraps them so not nearly your weather requirements and there's no mushroom growers up here.
Thats a lot of repair work. And not cheap, either.
   / The Life of a Custom Mowing contractor #1,506
I like the ones that fold up. My cousins folds back. Seems like a lot of stress when bouncing not to mention the tail swing. So far his is the only one I've seen like that.
   / The Life of a Custom Mowing contractor #1,507
Ouch that is going to hurt both in labor and the pocket book. I see that the outer pto shield is missing they seem to get damaged and tore up easily when working equipment hard and then they are such a pain in the butt to find the correct one and replace them.
I would hate to try and count the number of unguarded shafts around. I can think of close to dozen off the top of my head.
Then a cable or hydraulic hose gets down close in a tight turn and bam, there it goes.
   / The Life of a Custom Mowing contractor #1,508
Interestingly, I had to remove the outer PTO shield on the cabbed M9 so as the final CV joint and shroud would clear, something I wasn't crazy about doing but I could see no other practical way to gain clearance. On the Kubota bailer, the monitor is hard mounted in the cab on the right side above the FEL controls and the harness come in through the back window and plugs into the control box monitor with a 1/4 turn multi contact plug. Everythijg else stays on the outside but I'd probably have a heart attack if I got my leads (hydraulic and electrical) caught up by the spinning PTO shaft. That could be a quick couple grand fix...
I'm always doubly careful to use rubber bands (tarp straps) to sequester all the conncetions to the tractor from the bailer or mower where there is no chance they could contact the spinning PTO shaft and I check to make sure they aren't over extended or under extended in a hard left or right hand turn as well.
My NH centerpoint discbine has a really nifty spring loaded capture arm and the end of the draw tongue that keeps all the hoses and electrical stuff up and away from anything rotating. Has a 'U' shaped end with a cross arm that is captured with a hitch pin so once you run all the hoses and electrical stuff through it and capture it. it don't go anywhere.
   / The Life of a Custom Mowing contractor #1,509
Lou.. My biggest fear besides loosing my fingers or my scalp in the spinning PTO shaft (would be had to loose any scalp as I'm pretty bald), is winding up any electrical, electronic or hydrauic connections in the PTO shaft and having to remove the shield to fit the Kubota bailer's pto shaft to the back of the tractor still gives me concern. I realize back in the day, tractors didn't come with rear shields and mine was easily removable (4 bolts) but I still don't like it. Discussed it with my dealer and neither of us could see any way around it, so it came off.
The one thing that always gives me concern is a rotating pto shaft. Lots of farmers around here are missing fingers and scalp from just a second of being inattentive. My most 'fearful' implement os my grain leg because I have to be out of the tractor with the pto running and making sure the grain is flowing into the hopper so I'm right there, close up and personal with the parts that could cause me great greif. In fact, been thinking about converting the grain leg to an electric motor and doing away with the PTO, entirely.
Way back in High School, I witnessed another student literally rip his scalp out with a drill press. He got too close to the spinning drill chuck and bam, that was it. I'll never forget that, ever. Always kept my hair short and now the lack of hair eliminates that issue for me.
   / The Life of a Custom Mowing contractor #1,510
Yes, they can be hazardous for sure. On the farm we still use self unloading wagons into an ag bagger for haylage and silage. So you are often standing between the tractor and wagon with the pto shaft spinning engaging and disengage the wagons drive until the feed table is cleared out, then the apron chain is engaged and the speed is set. Until a large clump comes over the beaters and you have to hustle to prevent clogging or stalling something.
So 2 pto shafts and the wagon one's are connected and disconnected frequently during the course of a day.
I think the newest wagon is 20 years old the others are up to 40.
My favorite tractor end pto guards are the larger flip up ones that will flip up out of the way to get those heavy pto shafts and couplers in.
The fender mount pto switches come in real handy, you really miss them when you are using one of the older tractors and have to climb 2-3 steps up onto the platform to reach the pto and flip it on or off, lots of moving and twisting and turning in a small area.
And then the bagger keeps moving forward as the bag is filled, so up on the unloading tractor to keep the discharge chute were it needs to be, about a foot of back and forth play to maintain.
Those 100+ hp rated pto's get pretty substantial.
I won't say that we get lax but we certainly avoid floppy clothes and especially for me the hair isn't an issue.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
2015 POLARIS 1000 HIGH LIFTER RAZER (A57192)
2015 POLARIS 1000...
UNUSED FUTURE FTHJ6 40' - 6 SECTIONS HEAVY DUTY (A57193)
UNUSED FUTURE...
2022 BOBCAT S740 SKID STEER (A52707)
2022 BOBCAT S740...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
2019 CATERPILLAR 242D SKID STEER (A52707)
2019 CATERPILLAR...
