The B2650 count down has begun!
/ The B2650 count down has begun! #301
Rkidd,
It痴 very similar to the prince valve you used, except 3 spools and no float. I couldn稚 really think where I would need the float. If I find myself needing float I can add it whenever. I am not sure exactly on mounting locations yet. If I can get it in down next to the transmission I will probably have to remove the steel tube that comes factory with the 3rd function kit. I planned on having the valve in my hands a week ago to start getting a game plan together. Seller said if it doesn稚 show up tomorrow they will send a replacement out. USPS clearly lost it.
Yes I知 gathering implements. I had quite the selection for my bx but sold them all as they will be to small.
Currently have a front plow, rear blower. And a new land pride box blade.
I plan on buying a tiller, a rear blade,pallet forks,, and a grapple grapple soon.
My dealer said he would make me a **** of a deal on a 84 landpride rear blade(not sure why he wants to get rid of it so bad)
It will be to big for my tractor. But if it is that sweet of a deal I will get it and cut 6 off each side to make it the correct 72 I need
Alot of snow removal equipment. Do you guys get that much snow where you are at? Love my 66" Land Pride tiller and my 48" pallet forks, and was at my Kubota dealers today, looking for the next thing which is a grapple now that I have front hydraulics. When you get your spool valves and if you have any questions, let me know as I have spent alot of hours getting everything fit in. It really fills the space up in a hurry!!
/ The B2650 count down has begun! #302
That’s the funny thing, we don’t get much snow. Not like we used to at least. I got a pickup truck plow for 50$ converter it to skid steer quick attach with a 40$ adapter plate. Bought a hydraulic cylinder to angle the blade for 50$. So I have about $140 in a heavy duty front blade. The rear blower was just a local craigslist deal i thought was to good to pass up. It will probably never really get used. But I like painting projects. If I don’t get much use out of it I will sell it.
I have a line up on a 60” tiller. A 66” would be better(size of my box blade). But the land pride units are expensive. I don’t even have my own garden. But my parents do and I do a few more. I got a good deal on the one I had on my bx. Paid for itself the first spring.
I would like to get another one and keep doing some Gardens. But if it takes 3 years to just pay for the tiller it doesn’t really make sense financially. If I had my own garden to do it would make the decision easier.
Not really, I put the 72" back blade on it 2 different times to plow snow... But that doesn't count as real work in my opinion. I'm a couple months from dry enough ground to get into my property to start really doing dirt work with the blades.
/ The B2650 count down has begun! #305
I just want to let you know to be careful with non standard implements. My snow blower was fine when the standard tires were on my tractor. But now that I have the oversie tires the nuts/bolts that hold the stabiles bars are almost touching the tread of be tire. This is because the snow blower is old and the mounting pins are wider than standard(quick hitch won’t work). I am going to move the pins to the inside instead of outside. Shouldn’t be a issue with new implements. But just wanted to make you aware if you need to spread the arms wide they will in fact contact the tire lugs.
I have an ancient back blade of unknown vintage and origin, but as long as the sway bars are nice and snug it's got a couple inches in each side.
/ The B2650 count down has begun! #307
Good deal. I wor working with 1/4”. It would rub each tires if it barely swayed. I had the bars as tight as I could.
Yes, if I was 1/4" I'd be moving those pins or rewelding the pin plates.
/ The B2650 count down has begun! #309
I might modify it to work with the quick hitch. But it won’t be easy. So I might just turn the pins around and call it good. It will go on when we get a big snow and probably stay on till spring. Not like I am taking it on and off all the time to worry about utilizing the quick hitch.
/ The B2650 count down has begun! #310
Valve finally showed up after being lost in the mail. Got all the fittings after work today. Just need to fab up the mounting bracket and make the hoses.
Then comes making the handles. Probably won稚 get to it till early next week though.
/ The B2650 count down has begun! #311
Hey Dan. Glad you got your spool valves finally. Where does it look like you will be able to mount it now that you got it and can physically hold it in place? Looking forward to watching your build.
/ The B2650 count down has begun! #312
Ron,
Probably going to mount it the same way as yours. You weren’t kidding, you run out of room fast. I almost wish I would have just went with a 2 spool valve. But the 3 spool was actually cheaper. And more is better. I think...
I wanted to mount the valve down under the tractor so you didn’t see it. And then run hoses back to a bulk head to mount the couplers. It would have been a cleaner install. But I think the lever setup would have been harder. And the valve probably would only be another 8” forward so it doesn’t make much difference. If I was really worried about the looks I should have spend 1300$ and bought the setup for the b3250 like KYLEH did and it would have been the best way. But this setup I’m in about 275$ and I shouldn’t need any more materials.
/ The B2650 count down has begun! #313
Ron,
Probably going to mount it the same way as yours. You weren稚 kidding, you run out of room fast. I almost wish I would have just went with a 2 spool valve. But the 3 spool was actually cheaper. And more is better. I think...
I wanted to mount the valve down under the tractor so you didn稚 see it. And then run hoses back to a bulk head to mount the couplers. It would have been a cleaner install. But I think the lever setup would have been harder. And the valve probably would only be another 8 forward so it doesn稚 make much difference. If I was really worried about the looks I should have spend 1300$ and bought the setup for the b3250 like KYLEH did and it would have been the best way. But this setup I知 in about 275$ and I shouldn稚 need any more materials.
Hey Dan. The way mine is set up you dont see it at all except from the back where the couplers are, and the levers sticking up. It ended up a pretty clean looking install. For sure that space is limited but doable. One other thing to watch for especially with a wider spool valve, is that nothing is in the way when the 3pt arms are all of the way up. I had my valves as close to the right fender as I could and my hose running down to the loader valve just clears. It was tight even with my 2 valve setup. The other thing like you said, is the the farther away the valve is and the longer the levers, the longer the throw will be on them. That is another reason I did mine like I did. The lever movement is good.
/ The B2650 count down has begun! #314
Mine will be mounted tight against the fender also. Everything looks like it should work. I need to fab up the bracket so I can bolt the valve to it and make mocking it up a little easier.
I ran to the local Kubota dealership this morning and grabbed all fluids and filters to do a 100% change for my upcoming 50 hour service, also grabbed a pistol grip grease gun and 3 grease cartridges... And another hat. About $260 total with hat and grease gun.
Fuel filter, front axle, engine oil/filter, HST fluid and filters, air filter. That will get the machine to a good start.
/ The B2650 count down has begun! #316
Larry,
Glad to see your going to change the hydro fluid. I am going to also at 50hrs. Cheap insurance
Let us know how it goes.
/ The B2650 count down has begun! #317
Definitely the way to go. Get the bracket fabbed up and do a mock up to make sure everything fits and yoi can get all the hoses rin to where they have to go.
/ The B2650 count down has begun! #318
Made a little more progress tonight.
Got the bracket made and painted tonight. Got the two hoses cut to length. I am going to crimp the fittings on tomorrow. One thing left is to get that tee from Home Depot Ron suggested. Shouldn稚 take
More than an hour to plumb it in. Then comes making the levers.
/ The B2650 count down has begun! #319
Looks good so far:thumbsup:
/ The B2650 count down has begun! #320
Looking good Dan. Looks like it is fitting in there really good!!
