ttstraw
Man do I feel like a goob! Bringing firewood in tonight, we fill the bucket and then lower it into the BilCo doors and my boys unload from the basement, saves the up and down steps thing. Anyway, lower the bucket in idle everything down and stand up...tractor dies! Shut the lights down and try to restart...nuttin...! Play with the hydro pedals, set park brake and try again...nuttin. Everything lights up but no crankin. Run inside find the manual, have no idea where the fuse block is, back outside tear screen cover off, check fuses visually, all look good. Still no crank. Down on the ground, snow covered as it is snowing out, looking for a saftey switch on the hydro pedals...all looks good still no crank. I notice there is a slow blow fuse down by alt....cant reach that joker unless you pull the shroud off....cant pull the shroud off unless you remove the grill guard. Tear all this off and check the slow blow and re-check all fuses with multi-meter...all good. Now I am getting a little frustrated..thinkin...cant start tractor...bucket lowered into BilCo opening so I cant close those doors nor even yank the tractor away from the door with the truck, the thought of calling the dealer and them seeing this thing like this was really getting to me. Then I think, the batt, not enough juice to run everything....pull it out put it on the charger. Slip on to this site and start to searches while its charging. See some comments about hydro pedals and PTO lever, I know of both of these but I never touched that PTO lever, cant be it I thought. Batt done charging, suit up and back out I go. Hook the batt back up and hit the key, nuttin, barely touch the darn PTO lever and away it went. Man did I feel like a goob. I touched that thing again and I will say it does not take much to shut that engine down. Still need to put the grill guard back on, it will wait its too cold but at least its back in the garage now. I am looking on the bright side of this, at least I now know where the fuse block is, the slow blow fuse, how to remove the shroud, got a good charge on the batt, and I have a hyper sensitive PTO lever. Not to bad a night...oh and I got two buckets full of firewood in the house..!!
