TF300 vs JD303
/ TF300 vs JD303 #1
kayssupply
Platinum Member
S Illinois
Iseki TA 207
I know it is common knowledge that JD 303 is the hydro-trans fluid of choice. My question to the old heads is, what is the difference between the TF300 and the TF500 that two different tractors I have says to use in their transmissions. There has to be some difference. I know that when I change the original red fluid out and replace it with JD 303 the pump gets noisier when cold. I had a Hinomoto that would have ghost movements in the three point lift until it got warmed up. It would not do it with the original fluid. If the answer I need is back at the old group just say so and I'll go back and wait to get on and look for it.
/ TF300 vs JD303 #2
That's a good question. Of coures JD303 is a oil spec. I don't know what TF300 & 500 are. Are either 303 compatible? I have been reading the Oil,Fuel & Lubricants forum. People over there are big on synthetics. The synthetics are suposer to cure the exact problems you mention. I wonder if there is a synthetic Hy/tran fluid that would be good for us.
Chris
/ TF300 vs JD303
The TF 300 and TF 500 are on decals located by the trans fill and check plug on my Grey Yanmars. I have had super luck with synthetic engine oils. I have not tried any in transmissions.
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
